Sudden Fuel Pump Whine
32k miles on it. No codes or issues as of yet.
Filled the tank from 1/2 and the fuel pump noise subsided. Drove from Santa Fe to Colorado and around there for 2 days with no issues. Drove from Colorado to Amarillo and the following morning the car wouldn't start. Cranked strong but wasn't catching. Swapped fuel pump relay for another one and it fired right up. Made it to just outside of Austin where I had to fill up and it died shortly after starting it at the gas station. Again, flipped around relays, and it fired up.
Now I'm home, the car is as hot as it can safely be, and it's idling a little lopey and makes me a little worried it'll die while idling eventually.
Drives great with no stuttering at any throttle position. I'm real confused. Searched and found 05s seemed to burn up relays from bad wiring in the harness. Would this be applicable to a 12? I've never had this issue until putting the car through the heat gauntlet of driving 30 hours round trip through TX/NM/CO.
I cannot figure out why this fixes the problems. The relays aren't dead because where I'm swapping them into is unaffected and still functions. My best guess is by removing and replacing the relay I'm possibly fixing a bad connection in the terminals or resetting something.
