Trunk insulation material
Old Aug 29, 2019 | 01:18 PM
dkoch's Avatar
dkoch
Default Trunk insulation material
Hi folks
I have a 2013 Grand Sport.
I noticed that anything I set on the trunk carpeting, pretty much starts to cook after a longer drive.
Is there a good material I can have installed to form a heat barrier between the floor of the trunk and the underside of the trunk?
Derrick
Old Aug 29, 2019 | 02:17 PM
5knives's Avatar
5knives
Get a roll of bubble insulation at Home Depot/Lowes. Cut pieces to fit the area and you can lift the carpet from behind the seats to push them under. No need to climb under the car and it's easily removable.
Old Aug 29, 2019 | 02:44 PM
Kenny94945's Avatar
Kenny94945
Interesting, not many as I recall have mentioned this heat issue/ heat sink from the diff or mufflers into the trunk.
(The center console heat sink is another thread)
As mentioned in a thread above, a Home Depot heat barrier under the carpet may work for you.
There are more expensive automotive products that do the same (sound and heat) and typically apply with glue.
I'd ask, are you sure the heat issue from the drive train/ muffler and not from the Sun's UV rays through the back glass?
Old Aug 29, 2019 | 06:56 PM
dkoch's Avatar
dkoch
Thanks for this tip. Appreciate you taking some time.
Old Aug 29, 2019 | 07:03 PM
dkoch's Avatar
dkoch
Hi,
Thanks very much.
Ok, so as far as I know, the item that got fairly warm, was shielded by the spare solid yellow top which was in the trunk at the time.
On the other hand, a bottle of wine on the passenger floor mat, remained almost cool to the touch. No doubt the AC helped that. But sometimes I drive barefoot, and so it seems the floor of the passenger area remains pretty cool even in hot weather.
Old Aug 29, 2019 | 10:55 PM
farmington's Avatar
farmington
Get a water heater insulation kit from Home Depot.
Old Aug 29, 2019 | 10:58 PM
dkoch's Avatar
dkoch
Thank you
Old Aug 30, 2019 | 05:41 PM
4SUMERZ's Avatar
4SUMERZ
I used the insulating/heat kit from Exotic Vette. The kit comes complete to insulate the entire interior, and is pre cut to fit exactly.
It helps with heat, and noise reduction as well.
http://www.exoticvette.com/c6-insulation-kit.html
Old Aug 31, 2019 | 06:16 AM
R1banshee's Avatar
R1banshee
Try this stuff out. It worked wonders
https://www.amazon.com/gp/product/B072WHC63F/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B072WHC63F/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
And
http://ddaudio.com/products/installa...adening/ea-3-1
Old Aug 31, 2019 | 01:23 PM
HOXXOH's Avatar
HOXXOH
It's the quickest, easiest, and cheapest way to insulate from both road noise and under car heat. Cut it with scissors and tape it in place with the aluminum tape found near the insulation area. If you want extra protection for the carpet and from noise, buy those moving blankets from Harbor Freight.
Old Sep 1, 2019 | 02:10 AM
dkoch's Avatar
dkoch
I will check this link. Thank you
Old Sep 1, 2019 | 09:51 AM
maverickmk's Avatar
maverickmk
That is a good price for a pre-cut "plug-and-play" setup. Thanks for the link. I'll be getting this soon.
To Trunk insulation material
