Coolant change
Old Sep 10, 2019 | 08:47 AM
Lee Read's Avatar
Lee Read
Cruising
Default Coolant change
Hi, I just changed the coolant and thermostat in my 2006 c6, is there a procedure to bleed the system that should be done. The engine is getting up to 208 degrees so I shut it down.
Old Sep 10, 2019 | 11:42 AM
FLC6GS's Avatar
FLC6GS
There are about 6+ replies ahead of mine in General Discussion thread you have duplicated. You should check and follow that one.
Old Sep 10, 2019 | 11:55 AM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
And he still hasn't described the method he used to drain and fill. My advice is to start over if you think there's a problem.
Here's the process many have used:
Change coolant every 5 years or 150,000 miles, which ever comes first.
Buy 2 gals Prestone Dex Cool (Walmart) and 6 gals distilled water. I used 5 gals of distilled water this year
and flushed it twice. I think three flushes would have been better.
1) Drain coolant (drain plug is on passenger side). Approx. 8 qts out of 12.6 qts will actually drain.
2) Pull Surge Tank and clean out crud. Refill surge tank to the neck with distilled water.
3) Start engine, idle 4 min
4) Top off surge tank
5) Rev engine at 2000-2500 rpm for 2 more min. (temp should reach ~200 F)
6) Shutoff engine, cool for 20 minutes
7) Repeat steps 1-6 until fluid drains clear (2-4 flushes)
8) Refill with 6.3 qts Dex Cool (it's a slow process) and then top off with distilled water.
9) Repeat steps 3-5, take test drive, refill as necessary with distilled water.
10) Dispose of your old antifreeze at a recycling center.
Old Sep 10, 2019 | 11:59 AM
03BlkZ's Avatar
03BlkZ
208 is a normal temp! Most cars these days run 205-210. Just because you may have a 187 thermostat doesn't mean that's where the coolant temp will be.
Old Sep 12, 2019 | 07:41 AM
WW7's Avatar
WW7
205 to 210 is not a normal driving temp.. If your car runs a constant 205 -210 while driving down the road something is wrong ..Most run 194-196 while moving above 35 mph...There is probably air in the system that needs to work it's way out. Just drive it up to temperature, then let it cool off , then add more fluid ..After 3 or 4 hot/cool cycles the air will work out of the system and you should be fine...WW
Old Sep 12, 2019 | 09:05 AM
03BlkZ's Avatar
03BlkZ
I have to disagree but I am also talking about Z06 as opposed to what the OP seems to be talking about a base model. The 7.0 liter engine does run around 198 to 200 but when in stop and go it is between 205 and 210. This is very common especially in hot climates like where I am in TX. Some people in Arizona say their normal operating temps are 220 plus in the heat of the summer.
To Coolant change
