2006 Operating Temperature
Old Sep 10, 2019 | 12:29 PM
Fooddummy's Avatar
Fooddummy
2nd Gear
Default 2006 Operating Temperature
Just purchased a 2006 convertible. Got to drive about an hour today here in MI with a temperature of 77 degrees. The temperature gauge was at 215. Is this a normal temp?
Old Sep 10, 2019 | 02:19 PM
luka2sb's Avatar
luka2sb
i hope someone else will answer as well, but i think that's normal when stuck in traffic or idling in a parking stop.
when you're moving at say 40 to 50 mph constantly, it should be a lot cooler , about 190 F or so.
for peace of mind look under it to make sure there aren't a bunch of leaves clogging up the radiator
Old Sep 10, 2019 | 02:31 PM
sonnysucks's Avatar
sonnysucks
coolant temp? I run just under 200 as mentioned, oil temp, i see 230 after runs and in traffic... also supercharged.
Old Sep 10, 2019 | 03:10 PM
maverickmk's Avatar
maverickmk
I think 215° is a bit high, especially for your ambient temp. Here in Orlando it's around 95° today and mine is running around 200°-205°
Old Sep 10, 2019 | 03:35 PM
4SUMERZ's Avatar
4SUMERZ
My 2006 runs around 200 F most of the time, but I have seen it as high as 219 F when standing in traffic.
If you have time, check the front of your radiator for leaves or debris, and occasionally backflush the radiator fins on the engine side with a water hose to clean any debris caught in betweeen the fins. That could affect air flow for sure.
Old Sep 11, 2019 | 07:46 PM
NY09C6's Avatar
NY09C6
That should be normal. As long is it drops right back down to the lower 190s once you start moving I would not be concerned.
Old Sep 11, 2019 | 07:51 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
At cruise 190-194 is normal
Old Sep 12, 2019 | 07:18 AM
WW7's Avatar
WW7
I agree, mine runs 194-196 when moving down the road with A/C off , with A/C on it runs about 199-200..It also depends on which thermostat you have in the car.. When I had a 187 degree stat it would run 190-194 , with the 195 stat I have in now it runs about 194-196 average .....WW
Old Sep 12, 2019 | 02:01 PM
sonnysucks's Avatar
sonnysucks
Honestly, it's probably less supercharger and more intercooler in front of the rad?? Forgot about that piece of it.
Old Sep 15, 2019 | 11:31 PM
compyelc4's Avatar
compyelc4
Mine has always run at 205 degrees F. My '95 C4 has always run from 188 to 197 at freeway speeds.
Old Sep 16, 2019 | 09:06 AM
Narddog's Avatar
Narddog
200-225 is considered normal
Old Sep 16, 2019 | 10:19 AM
jashmore1234's Avatar
jashmore1234
Do you have a front license plate blocking air flow.
Look for debris between evap and radiator.
check radiator fluid level.
Have you cleaned the evap and radiator.
To 2006 Operating Temperature
