question, replacing the window regulator c6
Old Sep 12, 2019 | 11:43 PM
tonycorvettes's Avatar
tonycorvettes
Default question, replacing the window regulator c6
if you replace the window regular can it be done without a teck2 in other words can you just pull it out and put a new one plug and play? my problem is only my inside door button does not open the door latch,,,i was told by the dealer it is the window regular ,window works find ,,do you guys agree? tonycorvettes
Old Sep 14, 2019 | 04:40 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
If you're saying that the problem is the door latch not responding to the interior door button, then that has nothing to do with the window regulator. Easiest first step is to open the door panel; disconnect the connections to the button & check the button for continuity with a VOM. If the button is good, clean the contacts on the button & in the connector; reassemble & you should be good to go.
Old Sep 15, 2019 | 04:09 PM
carsnpars's Avatar
carsnpars
My 05 has an intermittent button problem. Sometimes when you hit the button the window will index down and back up but the door does not open. I put in a regulator last year after the window was SCREAMING going up and down. You can pop the button out without taking the door panel off. I’ll try what you sugggest
Old Sep 21, 2019 | 09:12 PM
tonycorvettes
wrong
Old Sep 22, 2019 | 09:47 AM
Buddy A's Avatar
Buddy A
regulator assembly can be replaced without tech II. Plug and play. Although I doubt there is a connection between the two.
To question, replacing the window regulator c6
