443 LS7 NA build
Old Jan 30, 2020 | 03:34 PM
old motorhead's Avatar
old motorhead
Originally Posted by Creatre
So I just finished my 447ci and have a similar dyno graph to you (and a very similar cam, same duration just on a 116 and .658" lift). I think mine might be related to pushrods holding the valves open because I just measured them to be about .010-.015" too tight. But hoping that's all mine is and I don't follow you down a similar path. Sorry about all the difficulty you've been through, I know how much of a let down it is to finally be done with everything just to tear it apart again!
My pushrods were too long in my LS3 build. I had some 7.4" ones "in stock" from another build. Figured I'd try them. They had about 1.625 turns past 0 lash of the rocker arm bolts to get to 22'/lbs. Engine nosed over pretty hard at 6200 rpm. Ran fine under 6200. 7.35" push rods cured things. It revs clean to 7K rpm now.
