New Clutch, no reverse, leaking brake fluid
Old Oct 20, 2019 | 09:25 PM
kjcmusic17's Avatar
kjcmusic17
Default New Clutch, no reverse, leaking brake fluid
Well, 2 steps forward, one step back. Got the remote bleeder tightened up and now my clutch engages and disengages, but a test drive around the neighborhood revealed that
A) I cannot get my new MGW shifter into the reverse gate so I'm gonna check the lockout solenoid fuse. 1-4 are perfect. I can get into 5 and 6 but haven't tried them while moving because
B) I have a brake fluid leak at the rear of the vehicle. I suspect it to be the hardline union on the driver side. I disconnected that union to drop the rear cradle. Perhaps I didn't tighten it enough when putting the car back together.
Any tips?
Old Oct 21, 2019 | 11:13 AM
Dutch08's Avatar
Dutch08
SWAG here ... Did you use the MGW alignment tool when tightening the pinch bolt?
Old Oct 21, 2019 | 12:32 PM
kjcmusic17's Avatar
kjcmusic17
I I did! I also tighten the pinch bolt as much as I could to avoid any slipping.
Old Oct 21, 2019 | 01:31 PM
kjcmusic17's Avatar
kjcmusic17
Also I checked the fuse for the reverse lockout and it looks good. Maybe I missed reconnecting the reverse lockout solenoid, but I thought I hooked up all the connectors to the transmission.
My next steps are checking the wires to the transmission and the shifter alignment, but I would think if the shifter was misaligned, I wouldn't be able to get into the other 6 gears. It just seems that the reverse lockout is the issue as I cant get into the gate. I haven't tried to force it in.
Old Oct 21, 2019 | 02:18 PM
Dutch08's Avatar
Dutch08
SWAG 2, You have an '05 if I recall, if so you have 2 reverse sensors on the transmission. Make sure connections are both firmly attached.
Old Oct 21, 2019 | 02:24 PM
Dutch08's Avatar
Dutch08
SWAG 3, Was the transmission in neutral when you used the MGW alignment tool ? (There is no neutral in a manual, but you get the idea)
BTW: If the MGW shifter is removed you can shift the transmission with a small wooden stick. I use the wood handle part of my small ball peen hammer.
Old Oct 21, 2019 | 03:24 PM
kjcmusic17's Avatar
kjcmusic17
I have an 08 so Tr6060.
It was in neutral when I aligned it. It's currently in neutral now so I may try re-aligning. That's a good idea with the stick/hammer. If it was misaligned though, wouldn't I have a problem with more than just reverse? Wouldn't I have any issue with other gears as well?
Old Oct 21, 2019 | 06:53 PM
3X2's Avatar
3X2
my swag. Did you connect the rev solenoid connector to the skip shift solenoid and vice versa?
Old Oct 21, 2019 | 07:15 PM
kjcmusic17's Avatar
kjcmusic17
Figured it out!
I didn't plug in the reverse lockout at all. Works fine now! Brake Union was loose. Tightened it up, no more leak! Took her for a spin and all is well!
Thanks for all the help!
To New Clutch, no reverse, leaking brake fluid
