C6 Z06 clutch issues
Old Oct 23, 2019 | 08:54 AM
jvcobra's Avatar
jvcobra
Cruising
Default C6 Z06 clutch issues
Having some weird clutch issues with the Z06 I recently bought. When putting the car into gear with the clutch pushed to the floor the car will not shift into gear. With the clutch released 1/4-1/2” the car goes into any gear with ease. When engaged in gear it is very difficult to get the car out of gear with the clutch fully depressed but again moves with ease when the clutch is 1/4-1/2” from the floor. Not to mention once I’m in gear the clutch seems to slip in all gears above 1/2 throttle. Any thoughts? I assume I need a clutch due to slip but the weird not engaging with clutch fully depressed has me stumped. 07 with 35k miles.
Anyone experience something similar or have any ideas?
Old Oct 23, 2019 | 10:27 AM
sonnysucks's Avatar
sonnysucks
Sounds like a worn / dead clutch and throwout bearing. I think that's what causes the inability to shift / notchy shifting. You'll want to make sure your clutch fluid is clean as well, i'm sure with a new setup you will give the whole system a once over and be good.
Old Oct 23, 2019 | 10:33 AM
corvettekent's Avatar
corvettekent
2023 Corvette of the Year Finalist - Unmodified
2022 C1 of the Year Winner - Unmodified
Sounds like you need a new clutch and while you are in there install a new slave cylinder.
Old Oct 24, 2019 | 09:14 AM
spartan8270's Avatar
spartan8270
Monster LT1-S, new GM Slave with Monster Billet Bearing support, remote bleeder and new GM updated Master Cylinder. Should be around $1300 in parts. Got all mine from Tick Performance. Mine had same issue as yours
Old Oct 25, 2019 | 12:47 PM
jvcobra's Avatar
jvcobra
Cruising
Now that I've come to terms the fact that I need a new clutch... I've been considering pulling the motor instead of going through removing the rear cradle, torque tube, etc etc. Maybe a few more things to disconnect but I much rather not be on my back pulling out the driveline. Can anyone speak to both methods?
Old Oct 25, 2019 | 02:16 PM
spartan8270
You can have rear cradle and torque tube out in under a few hours if you've never done it. Much easier. Youll have to disconnect brake lines in rear and bleed after but it's much easier than yanking the motor.
Old Jun 10, 2020 | 11:32 PM
Speedy007's Avatar
Speedy007
have to say between ya king the motor and doing a clutch is about the same time frame. For any person experienced with this car model.
Old Jun 11, 2020 | 04:03 PM
Dutch08's Avatar
Dutch08
IMHO, If you are going to do it yourself it is far easier to drop the rear cradle having done it twice myself. However, you will have to lower the front cradle (about an inch) to get at the top bolts of the bell housing.
No matter how you decide to do it, be sure to replace everything (ie. flywheel, clutch disc, slave (w/ bleeder), pressure plate, bolts, etc.)
Old Jun 12, 2020 | 08:40 PM
Dano523's Avatar
Dano523
Problem, would dare to guess that either tick master was installed and not adjusted correctly (over throwing the TB) to start with.
Since the clutch is slipping, then time to pull the drive line to replace the entire clutch system to start with, and if a Tick (tilton) master cylinder is in play, it needs to be adjusted correctly so it not over throwing the TB bearing forward with a full pedal push.
Hence tilton master cyclinder is wider ID than stock OEM cylinder, so will push more fluid with same amount of pedal push. So when adjusting the tilton master cylinder at the pedal, you have to add in some free pedal play at the top of stroke on the pedal adjustment, so at bottom of stroke/pedal to the floor, it not over driving the TB too far forward against the pressure plate finger springs(to bend them).
Old Jun 21, 2020 | 02:53 PM
HC Mechanic's Avatar
HC Mechanic
Any updates on what you found on disassembly?
Did you make any changes immediately prior to having these issues?
My guess is that Dano hit the nail on the head, looking forward to what you found though
To C6 Z06 clutch issues
