Intake manifold injector bore LS2/LS3
Old Oct 23, 2019 | 11:51 AM
dr_gallup's Avatar
dr_gallup
Default Intake manifold injector bore LS2/LS3
Almost every vehicle for the past several decades has a 14.0+/-0,1 mm bore that the bottom o-ring on the fuel injectors fits into. In their infinite wisdom, GM changed that at some point. I'm sure LS3 has a bigger bore, pretty sure the LS2 does as well. Not sure where the change over occurred. I need to know precisely what that bigger dimension is. I think it's about 14.8 mm. If anyone has an actual drawing that would be good. I've googled quite a bit & I've found articles with numbers all over the place. I need facts, not opinions.
For instance, this graphic is repeated all over the internet and I know for a fact it's wrong.
Old Oct 23, 2019 | 12:29 PM
jonjoy's Avatar
jonjoy
Injector connection in Cummings Ga might be the people to talk too
Old Oct 23, 2019 | 01:52 PM
dr_gallup's Avatar
dr_gallup
The aftermarket is completely unreliable. I want something from GM or Bosch.
Old Oct 23, 2019 | 03:16 PM
dr_gallup's Avatar
dr_gallup
Got it. 14.9+/-0.1 mm
To Intake manifold injector bore LS2/LS3
