C5 Differential On C6 Adapter Bracket?
Old Nov 1, 2019 | 10:19 PM
lstoys's Avatar
lstoys
Default C5 Differential On C6 Adapter Bracket?
Where can you find a good adapter bracket to mount a C5 differential on a C6?
Old Nov 4, 2019 | 10:57 AM
lstoys's Avatar
lstoys
Do most of you just make your own bracket then? The only articles I can find on guys doing this are almost ten years old.
Old Nov 5, 2019 | 08:04 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Check with this vender
http://www.rpmtransmissions.com
Old Nov 17, 2019 | 11:49 PM
lstoys's Avatar
lstoys
Jim, thanks but I do not believe they sell them.
Old Nov 17, 2019 | 11:53 PM
lstoys's Avatar
lstoys
I just saw a video uploaded October 2019 where these guys were installing a C5 dif on a C6 and said they had just bought the adapter plates that fit into the crossmember triangles, but they didn't say where - so somebody is making these. If anyone knows where to get a set please let me know, thanks.
Old Nov 18, 2019 | 12:06 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I've had good results with RPM.
http://www.rktperformance.com/?welcome-from-cf is the other vendor which can help.
Old Nov 18, 2019 | 01:21 PM
lstoys's Avatar
lstoys
Thanks, I'll look at contacting these guys and see.
Old Nov 18, 2019 | 01:22 PM
lstoys's Avatar
lstoys
When I look at older posts there seems to be a few different styles of brackets too.
One person complained of a lot of vibration using one of the adapter styles, not sure which one; if anyone has experience with these would be curious to know if you ran into vibration or issues.
Old Nov 18, 2019 | 05:21 PM
lstoys's Avatar
lstoys
Okay, so for the record neither RPM or RKT sell the adapter, but it was worth a shot so thanks for the ideas.
Old Nov 19, 2019 | 11:45 AM
lstoys's Avatar
lstoys
The adapter kits that I've seen pictures of basically fit plates into the triangles holes of the crossmember, you could probably just make yourself or cut templates and have them made; the rubber bushing in-between the crossmember and differential appears to be the only hard part?
Old Nov 19, 2019 | 06:01 PM
saplumr's Avatar
saplumr
I assume you're trying to save money but replacing with a RPM built C6 Z diff is what I did years ago.
Old Nov 19, 2019 | 10:42 PM
lionelhutz's Avatar
lionelhutz
I'm pretty sure those 2 outer holes on the top plate bolt right to the diff eliminating the factory C5 mount. That assembly bolted down with the bolt going through both plates with the bottom plate against the cradle certainly doesn't properly create a bushed mount.
The C5 mount might be too tall to fit in there. Otherwise, I'd wonder if you could use it somehow possibly with some plates filling in the holes.
Old Nov 20, 2019 | 10:06 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I wouldn't trust that mount to attach the diff. It is attaching to a point that wasn't designed to carry the load. Further the diffs tend to move around under load and aftermarket mounts try to limit the movement of the diff. The adapter in the video uses a single bolt on the subframe side.
I'd look for a C6 diff.
To C5 Differential On C6 Adapter Bracket?
