Air Filter Part Numbers
Old Jan 1, 2020 | 08:14 PM
KingCorvette93's Avatar
KingCorvette93
Default Air Filter Part Numbers
Hello All,
2010, base car
Going to replace my air filter with an ACDelco unit. However, two part numbers popping up (see links):Which is correct?
@dr_gallup made this thread a while back, but it concerns GS models... which I thought might be different than base cars.
Thanks so much!
Old Jan 1, 2020 | 08:34 PM
4SUMERZ's Avatar
4SUMERZ
ACDELCOA3077C{#15776148, A3077CF}Professional
Here is the GM factory parts list for it in their catalog (#14)
Old Jan 4, 2020 | 03:52 PM
hubes's Avatar
hubes
The difference between the 2 is that grill, part 13 in the diagram. With the A3077C the grill is a separate piece. With the A3107C the grill is part of the filter media.
Old Jan 9, 2020 | 12:40 AM
KingCorvette93
I purchased the A3077C (separate grill) on the recommendation of @4SUMERZ and the diagram. So, do I need to buy a new grill piece too? Or reuse the old one?
Old Jan 9, 2020 | 10:26 AM
4SUMERZ's Avatar
4SUMERZ
Remove the grill cover from the old, clean it and attach to the new filter element.
Old Jan 9, 2020 | 11:17 AM
hawkgfr's Avatar
hawkgfr
I thought we used the ls7 filter cause it was better?
Old Jan 9, 2020 | 10:35 PM
hubes's Avatar
hubes
The LS3 and LS7 filter are the same. The LS9 filter used to be a higher flow filter, but they changed it, and now it's the same
Old Jan 10, 2020 | 06:49 PM
hawkgfr's Avatar
hawkgfr
So they are all three the same...as the LS3 or the ls9.
Old Jan 10, 2020 | 09:30 PM
hubes's Avatar
hubes
Same filter material as the old style LS3/LS7. The later cars all came from the factory with the LS9 filters, likely to offset the power loss of the 4 cats. Now they only make the one material, but it comes with or without the grill
Old Jan 12, 2020 | 12:34 AM
KingCorvette93
Nice info!
Old Jan 16, 2020 | 12:30 AM
Bob Paris's Avatar
Bob Paris
I reused the old grill and life is still good!
To Air Filter Part Numbers
