Differnt ls7 intake ?
Old Jan 13, 2020 | 05:54 PM
Electron447's Avatar
Electron447
Default Differnt ls7 intake ?
As the title states ,I’m looking for an aftermarket intake manifold for around 600-650$ . I have an LS1 sleeved to 447ci and an LS7 top end . Car makes 560/514. I’m looking to bring my numbers up . I was wondering what’s a good intake out there for around the price previously stated . I have a budget and a deadline so I’m looking at that for price. Or should I just try and have a tuner try and squeeze out more . Car is on 93 only right now . I have e85 and 110 readily available where I’m at .
-Thanks .
Old Jan 13, 2020 | 06:45 PM
MTPZ06's Avatar
MTPZ06
Used MSD or FAST...unless this isn't a corvette and hood clearance isn't a limiting factor. Then I'd try to locate a used Holley high ram.
Not sure you'll find an MSD in that price range, but here's a FAST: https://www.corvetteforum.com/forums...ld-setups.html
Old Jan 13, 2020 | 07:57 PM
drewz06's Avatar
drewz06
thing knower
you can get msd for 854 from tick
https://www.tickperformance.com/msd-...ck-part-27013/
or you can use that url to get summit racing to price match
Old Jan 13, 2020 | 09:56 PM
xBoostx's Avatar
xBoostx
Not sure how much power you want to make but I’m over 600 wheel with the ls7 intake just mill heads for 13. Compression on E not a big cam 245 duration on the intake take a look
You can tell where the drop off starts on the top end and that’s where the intake runs out of breath but clearly you can top 600 with it I just did a quick last minute porting on it basically just ruffed it out.
Stock ls7 bottom end
To Differnt ls7 intake ?
