Buying thicker sway bars, do I need brackets?
Old Jan 13, 2020 | 06:31 PM
Michael Dene's Avatar
Michael Dene
Default Buying thicker sway bars, do I need brackets?
I’m thinking about upgrading my stock suspension on my 2007 base coupe to Z51 bars.
When I also buy the new corresponding OEM bushings, do I need to buy the brackets also, or do the original stock ones fit the same?
Old Jan 13, 2020 | 07:31 PM
SixAddict's Avatar
SixAddict
I recently did this to my 09 base along with Z06 shocks, you will be pleasantly surprised, it's a great up grade.
If you get them from Cultrag (forumvendor) the sway bars will come with the correct rubber and you reuse your OEM mounts.
Old Jan 13, 2020 | 07:46 PM
Michael Dene
Thanks sir. That’s what I was wondering if I could use my stock mounts.
To Buying thicker sway bars, do I need brackets?
