stuck in park
PM me for PDF instructions to remove the console, and also get at the locking pawl to release it, and tie it back if you want them both.
Good Luck
here is the switch that will work and replace the existing OEM switch.
The radio shack micro switch is not identical, but more robust than the OEM switch, and the roller makes up for the little bump that the OEM has to assure good contact with the plastic shifter lever assembly.
The RS number is 2750017
The Amazon switch which is almost identical to the OEM is Omron SS-5GL13/SL-1W3 Switch.
Those that have used the Amazon switch had to bend the arm out a bit to assure good contact with the shifter lever.
The 2 wires have to cut off the old switch, then soldered on to the new switch. One wire on the C (common) contact, and the other on the NO (Normally Open) contact, same as the wiring of the OEM switch.
the wires on the OEM switch are short, so when they are cut off, there is little room to resolder to the new switch. Most add a piece of wire to each lead to make them longer for more room to solder the wires to the new switch. They use heat shrink wrap to cover the bare wires of the lenghtened wires.
Cheers,
Scott
