Coolant Confusion
Old Jan 19, 2020 | 11:29 AM
CSixDude's Avatar
CSixDude
Default Coolant Confusion
I want to get rid of the DexCool in my car and switch to a different coolant type. I've done a lot of reading on different coolants (OAT, HOAT, P-HOAT) but I'm left a little confused about what the best choice is. And every manufacture seems to want a different coolant type/brand these days.
Does anyone have any good advise on the best (non-Dexcool) coolant brand/type to use in a C6 is?
NAPS Free means there is NO NITRITE, NO AMINE, NO PHOSPHATE, and NO SILICATE.
I'm currently leaning toward either P-HOAT or NAP free. I know I don't want anything with silicates, or borates. All the Japanese manufactures seem to have gone to P-HOATs, which appear to me (at least on the surface) to be the safest choice. I don't know alot about the new NAP free stuff yet. What say you?
Old Jan 19, 2020 | 11:43 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Just curious.....why do you want to replace the DexCool? I've used it for years with no problems.
Old Jan 19, 2020 | 12:03 PM
CSixDude's Avatar
CSixDude
DexCool has a very bad history, and none of the other manufactures will touch it. Most other manufactures will void the warranty if you use it in their cars. The 2-EHA (2-ethylhexanoic acid) used in it has been proven to soften and eat away at gasket material. GM had to actually use a different gasket formulation in their cars to resist the acid in it, and they had several class action lawsuits over it in years past.
I know that the gaskets in the C6 can withstand it, but I'd just like to get away from it. It also has shown to congeal when it gets air in it, which is why the coolant tank is now up high on the car, to help purge any air out of the system. DexCool has just such a bad history of known issues that I'd like to go another route with a coolant that doesn't have all these problems.
Old Jan 19, 2020 | 12:29 PM
CSixDude's Avatar
CSixDude
By the way, there is some really good info in this thread if you want to read through it.
https://mechanics.stackexchange.com/...ith-all-models
Old Jan 19, 2020 | 01:53 PM
farmington's Avatar
farmington
All of the issues with Dex are from when it first was used, 25 years ago. I haven’t heard of any Dex issues for a long, long time.
Old Jan 19, 2020 | 03:24 PM
aaronc7's Avatar
aaronc7
Only time I've had an issue was when I was ignorant on coolants and just matched color, I got that brown waxy nastiness forming in the expansion tank. I believe a lot of the reported issues are due to similar ignorance on the subject--I've had zero issues with Dexcool on this car and my 2014 Ford Focus was Dexcool also.
You're way overthinking this
Old Jan 19, 2020 | 08:35 PM
CSixDude's Avatar
CSixDude
Regardless of whether you think Dexcool is a good coolant or not, I'm looking to switch and would like to get some feedback on alternative coolants others may be using.
Old Jan 19, 2020 | 08:53 PM
MissileDoc's Avatar
MissileDoc
Use the blue in color coolant that the HONDA corporation supplies for the vehicle it produces.
Old Jan 19, 2020 | 09:02 PM
juanvaldez's Avatar
juanvaldez
The folks a bobistheoilguy seem to like G05. I've used it in lots of motorcycles.
Old Jan 19, 2020 | 11:56 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
If it isn’t broke don’t fix it. You are over thinking this.
Old Jan 20, 2020 | 09:18 PM
CSixDude's Avatar
CSixDude
That was the direction I've been leaning too. It's a P-OAT coolant without silicates.
Old Jan 20, 2020 | 09:32 PM
TucoTom's Avatar
TucoTom
Isn't DEX-COOL what GM recommends for the Corvette?
Old Jan 21, 2020 | 04:17 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Yes it is,but why would anybody want to use what is recommended by the manufacturer of the vehicle?
Old Jan 21, 2020 | 05:50 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
I believe the OP is saying if it isn't broke, fix it anyway.
Old Jan 21, 2020 | 07:44 PM
maverickmk's Avatar
maverickmk
I agree with this.
Old Jan 22, 2020 | 08:00 PM
BadAV's Avatar
BadAV
Never had an issue with Dexcool and I've had vehicles with it since 1993. Just maintain it properly and you won't have an issue.
Old Jan 24, 2020 | 04:22 PM
dr_gallup's Avatar
dr_gallup
GM spent a lot of time and money getting all the components in contact with the coolant compatible with DexCool and you want to randomly replace it with something else? Do you have a degree in organic chemistry? Yes there are other more modern coolants used (and tested) in other brands but chances are you will create more problems than you solve. I would just replace the DexCool on the 5 year scheduled maintenance and not worry about it.
If you really have to change it for changes sake, make sure you flush out the system really well. The vast majority of coolant problems are caused by people mixing coolants.
To Coolant Confusion
