So I just had my engine and trans out did a cam swap cleaned a few things up and now I have
Traction Control/ Active Handling Light. It comes on as soon as I start the car.If I unhook the battery and reset everything it will come on after a few second? I’m wondering if there’s any specific wires I should check out first.
Step one is to pull the code(s). Some auto parts stores can do it for free, but a good code reader that will read the ABS, Airbag, etc. codes is a good investment.
Scott
I am going to pick one up in the next few weeks.. could it have anything to do with the stage 4 cam / no rear O2’s without a tune?
I believe it’s due to it not being tuned.. I noticed if I start the car up and hold the rpms at 2k it won’t come on it’s the rough idle that kicks them on
