Do solid motor mounts break stuff?
Old Feb 1, 2020 | 05:00 PM
Vettelet's Avatar
Vettelet
Default Do solid motor mounts break stuff?
I thought I saw someplace that solid motor mounts + trans mounts break torque tubes....I CANNOT find that thread now that I am thinking about buying a set.
Any truth to that? I am thinking I remember that post recommending just engine mounts or just trans mount to give some 'give.'
Pretty sure the Level Zero Solid Mounts (Poly) or (Delrin) kits are goiod enough for what I want them for.
Car is a 09 :LS3 with limited street use (NVH who cares)
Old Feb 1, 2020 | 05:12 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Just out of curiosity ... Why do you think you need to switch to solid motor mounts ?
Old Feb 1, 2020 | 05:28 PM
Vettelet's Avatar
Vettelet
edit
Old Feb 1, 2020 | 07:39 PM
Vettelet's Avatar
Vettelet
Oh yes....and this thought that solid mounts cause the knock sensors to go nuts.
The Delrin, poly mounts can do this????? or just the aluminum ones?
Old Feb 1, 2020 | 07:41 PM
Vettelet's Avatar
Vettelet
This is the post/Thread...I finally found it
https://www.corvetteforum.com/forums...or-mounts.html
Old Feb 2, 2020 | 06:30 AM
Mark@AMT Motorsport's Avatar
Mark@AMT Motorsport
Supporting Vendor
Knock sensors going haywire and broken bell housings are the two things I've heard CAN happen with solid motor mounts. That's the reason we designed ours the way we do. It's a single bolt thru to keep the motor very much in place, but there's a very firm rubber sandwich to smooth out high end NVH.
__________________
Mark Petronis, 2023 C8 #266
President - AMT Motorsport
Mark@AMTMotorsport.com
Facebook The 'Gram
518-877-8560
Old Feb 2, 2020 | 11:45 AM
Vettelet's Avatar
Vettelet
Wow those things look amazing... Are those stiff enough you must/should replace the trans ones too? Im not sure I have found the best information regarding the proper/improper pairing of motor/trans mounts.
Old Feb 2, 2020 | 02:56 PM
Larry Myers's Avatar
Larry Myers
Have had Hinson motor and transmission mounts on my car in excess of seven years with no difficulty. Includes about 55 tracks days.
Old Feb 2, 2020 | 07:37 PM
Vettelet's Avatar
Vettelet
Thanks for the info, I picked up a set of them.
Old Feb 3, 2020 | 10:02 AM
Spaceme1117's Avatar
Spaceme1117
I have tried stiffer/solid motor mounts in a few different LS powered cars (2006 GTO, 2002 Z06) cars but I pretty quickly returned back to a stock mount as the amount of vibration was unbearable. I just don't think there is really any benefit especially on a street car. Now a full on race car, I can understand.
Unless, you like the feel of more vibrations and rattling the feelings out of your teeth.
Old Feb 7, 2020 | 04:57 PM
davidfarmer's Avatar
davidfarmer
I run solid aluminum but remove knock sensors. You shouldn’t do solid or almost solid on both ends
Old Feb 7, 2020 | 05:38 PM
Vettelet's Avatar
Vettelet
I think its a personal preference. My car wont see 2k miles a year, I have an actual DD.
To Do solid motor mounts break stuff?
