compression test on motor that can't start
Old Mar 9, 2020 | 08:34 AM
drewz06's Avatar
drewz06
thing knower
Default compression test on motor that can't start
hey all, I want to do a compression test before I pull my motor, but I got no coolant so I can't warm her up...
squirt some oil in the plug holes and test like that sound good?
I figure I'll follow the same method once overhauled so I can compare against the base test
drew
Old Mar 9, 2020 | 08:49 AM
CI GS's Avatar
CI GS
Why not do it the proper way: with a leakdown tester? They’re not that expensive.
Old Mar 9, 2020 | 08:51 AM
drewz06's Avatar
drewz06
thing knower
good call! any recommendations on brand? oemtools seems to generally make good stuff...
but I thought the motor needed to be warmed up for good ring seal?
Old Mar 9, 2020 | 08:57 AM
backlash2032's Avatar
backlash2032
You can still get a good idea of engine health with a cold motor.
Old Mar 9, 2020 | 09:02 AM
CI GS's Avatar
CI GS
OEM seems to be good quality, from what I’ve seen. I have a cheap Summit branded one, that has worked fine for years.
I think it would be ideal to check at normal operating temps, but you have no way of doing that, correct? I suppose you can then use that as a baseline l to compare to ring seal with the engine cold after the rebuild.
Why are you even bothering to check it if you’re rebuilding it though?
And, obviously, when you rebuild, you’ll want to get the rings broken in and seated properly before you do a leak down test to see if the leakdown rate is acceptable.
Old Mar 9, 2020 | 09:04 AM
juanvaldez's Avatar
juanvaldez
You can get one at Harbor Freight. You also need a compressor.
Old Mar 9, 2020 | 09:25 AM
C6_Racer_X's Avatar
C6_Racer_X
Sort of.
You'll get a fair indication of relative cylinder wall condition with a "wet test" with a bit of motor oil in every cylinder. Rings don't seal very well cold, so "dry" compression test results will be low. That could be actual ring issues, or it could be just normal cold conditions.
A flush with hot water is a way back to raise temps. Start by hooking the hose to hot water tap. You can boil 3 to 5 gallons of water in a turkey frier and pour that through for even more heat in the block.
It's better to start the engine. If you're going to steam clean or hot tank the block, just run straight water in it. If the radiator isn't available, put a corrugated hose from the upper hose fitting to the lower hose inlet. Just watch the coolant temp,either with a gauge, obd-ii scan tool, or with a point and shoot IR thermometer to watch the temp of the hose at the upper hose outlet.
Old Mar 9, 2020 | 03:20 PM
drewz06's Avatar
drewz06
thing knower
ahh well the bottom end is going to remain stock, not touching pistons/rings/mains... i just want to know what it is now, and if its close to after new heads/cam/clutch/etc...
looks like i got a cracked end tank on the rad, i suppose i could fill it back up with water, but i'd really rather not run it up to temp without doing a coolant purge/vac...
the motor runs fine, did a strong dyno pull recently.... i'm pretty sure the short block is fine, i just want to make sure i dont run in to any problems with push rods being too long or something that will make the compression numbers wacky....
To compression test on motor that can't start
