I would like to install a switch in the car that allows me to change the engine speed signal to the tachometer. In other words, the engine revs, say 3500 rpm and when I flick the switch, it shall only show 2500 rpm on the tachometer. What is the signal that runs to the servo/needle in the dash? Is this somehow possible?
Engine speed to the cluster is a pulse signal from the ECM. I'm not sure of the format but probably so many pulses per engine rpm. You would have to splice in a module that counts the pulses and then outputs a modified pulse train to the cluster.
Man! What an effort to get to this wire. Can we trace this back to its origin and access it a little easier? Does anyone have a wiring diagram.
I have the rest sorted on my end - in the most difficult case, I will read the signal with an Arduino, modify it, and send it back out to the dash in the modified fashion.
It goes to the under hood fuse block D8 then comes out at F6 and goes to the ECM. You'd have to trace it in the harnesses under the dash to try and find it.
