I got P1SC1 procharged corvette LS3 wet sump, manual trans.
I'm thinking to change HB but I don't know which one to go for.
As I searched for it on the forum ATI 917246 is the good choice.
What about Underdrive or Overdrive balancer ?
ATI is one of the best out there and have been around for 40+ years.You can't use an under driven balancer on a supercharged application.Easier to use stock size hb and change pulley size on blower if need be.Call ATI tech line at 410 298 4343 for p/n needed
I think so. I will buy standard size pulley.
thanks so much
To me, the best for an all-out supercharged application is the IW with the oversized blower hub. Not taking anything away from ATI, because they are really good dampeners, but IW no BS and is used by many reputable high-end engine builders and is the only one that I know that has that over sized hub feature. They can also be ordered with twin keyways, comes with IW’s own bolt and washer and IW’s optional crank pinning kit is pure innovative genius for non-keyed cranks.
All the higher end GM crate engines come from the factory with ATI dampeners on them as do the 24 hour endurance race engines run at Daytona,Sebring and LeMan's.I prefer ATI's pinning method 90 degree's to the crank with as many as 4 key ways if desired
