Hi guys i planing to install double cooler radiator for trany and engineMy Car running with single turbo rear mount
Any suggestions for reliable radiator? and i prefer aluminum madeEbay has many options do u recommend it?Need help and adviceThe engine oil is greatly highe 230f
Dewitts full size w/prospeed dual fans and fan controller. You might also consider a manual fan override switch if you sit in traffic or the staging lanes.
Add a 160 degree thermostat and you should be good to go.
Not cheap, but good to go.
Thanks for passing by i like the idea for override switch plz give the brand
Already having 160 thermostat and DeWitt radiator and dual fans but it is one side cooler for trany and i utilize factory controller, moreover i used to have electric water pump but i changed to machnical new oem
Yes DeWitt Double cooler not cheap im trying to find another brand within my budget
Once againg thx plz if u have any idea let me know
