Spark Pĺug read
Old Apr 24, 2020 | 07:51 AM
Charliemopic's Avatar
Charliemopic
Default Spark Pĺug read
Read this 41-985 plug.
Its out of my LS2 with an E Force for 5-6 psi boost. It sees boost every time I drive it. All 8 look the same.
Old Apr 26, 2020 | 01:55 AM
Dano523's Avatar
Dano523
The tint color on the porcelain electrode shield is just fuel additives.
The rest of the plug looks fine'ish.
As for the plugs you should be running with 6lbs boost on the LS-2, 41-104 plugs gapped at .039.
Old Apr 26, 2020 | 09:37 AM
Todds427's Avatar
Todds427
St. Jude Donor '12
Plug looks fine to me.
Old Apr 26, 2020 | 05:19 PM
Charliemopic
[QUOTE=Dano523;1601395511]The tint color on the porcelain electrode shield is just fuel additives.
As for the plugs you should be running with 6lbs boost on the LS-2, 41-104 plugs gapped at .039.[/QUOTE
I will get some.
To Spark Pĺug read
