Battery Replacement
Old May 6, 2020 | 08:05 PM
Barrier's Avatar
Barrier
Default Battery Replacement
I plan on replacing my Batter in my C6 I use a Battery Tender plugged into my Cigarette Lighter. If I leave that in when I remove the Battery will that maintain my presets? I know thy sell a 9V battery plug in for the same purpose will the Tender cause any problems for the electrical items in the car? ECM, window presets, Radio? I think it should work perfectly any thoughts on this?
Barrier
Old May 6, 2020 | 08:13 PM
BadAV's Avatar
BadAV
Barrier
The only thing you lose without battery power is the window indexing and the learned ecm settings. With the battery tender hooked up you should retain everything.
Old May 6, 2020 | 08:25 PM
Iceaxe's Avatar
Iceaxe
Yes, leaving your battery tender hooked up will save all your presets, including windows.
To Battery Replacement
