C6 driver side door won’t open
Old May 12, 2020 | 02:03 PM
Vett2run's Avatar
Vett2run
1st Gear
Default C6 driver side door won’t open
I am looking for any advice or help. I’ve replaced body control module and door lock mechanism. Also clean the door pad. But I still can’t get the door open. Whenever I press the door pad The window goes down in there is some movement in the door latch but not enough to open it also doesn’t open from interior button.
i’ve change the following items door pad door button door latch motor and BCM Still NG
i’m looking for a GM shop manual I’m sure there is a troubleshooting procedure for this problem
Old May 12, 2020 | 06:25 PM
irok's Avatar
irok
Did you change the fob batteries?
Old May 13, 2020 | 09:25 AM
1RFLMAN's Avatar
1RFLMAN
Does the door open when pressing the inside door button when sitting in the car? If not, the problem may be the door latch mechanism, harness connection or wiring.
Old May 13, 2020 | 02:53 PM
Stewie Hibbins's Avatar
Stewie Hibbins
Cruising
I have the same problem. It is intermittent sometimes it works ok. Changed key fob batteries seemed to work then failed again in a week. Sometimes unlocking with the fob pushbutton works. Sometimes locking & then unlocking with the fob pushbuttons works.
Window moves and door lock energizes yet no access. This problem was previously restricted to the driver’s door but has now been happening with the passenger door. Trying to find a Chevy service bulletin.
Old May 13, 2020 | 02:54 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Door pad. Swap it dude. I know you said you cleaned it...not enough. Swap er out man.
Old May 15, 2020 | 02:32 PM
WW7's Avatar
WW7
He said it wont open.using the inside button, so it's not the touch pad. I agree with it being the latch...WW
Old May 21, 2020 | 03:20 AM
c6_CJ's Avatar
c6_CJ
Leaning towards latch, make sure you replace with the correct one when replacing mine I found out All the online retailers had the incorrect part number for the part with keyless locking
Old May 21, 2020 | 03:14 PM
veneno's Avatar
veneno
I had the same issue recently driver's door 2008
ended up being the latch bought new one from advanced auto part # O3020431907ACD
no more issues
Old May 22, 2020 | 09:34 PM
Stewie Hibbins
Cruising
Default Thanks
Thanks for all suggestions much appreciated!
Old May 24, 2020 | 11:33 AM
AIR_RAM's Avatar
AIR_RAM
Not true... if the pad is making contact, it will prevent the inside from opperating. I had the same issue and had to roll my window down to open the door. I first cleaned the contacts of the original...that worked better however still had the same issue just not as frequently. Then I bought a new pad and have not had an issue since.
Change the pad... its cheap and easy!
SPEED SAFE, NICK
Old May 25, 2020 | 08:48 PM
Stewie Hibbins
Cruising
Default Thanks Nick
SPEED SAFE, NICK
Thanks! Now to find a how-to video.
Old Jun 3, 2020 | 05:12 PM
Stewie Hibbins
Cruising
I replaced the touch pad and it worked right away but had then I one occasion when the door failed to unlatch though, so still not 100% but definitely an improvement!
I certainly appreciate all the advice, thinking maybe a new latch is in my future, but I have sadly resigned myself to manual door unlatching when need be.
Cheers,
Stewie
Old Jun 4, 2020 | 06:00 PM
C6topless's Avatar
C6topless
The first action I would take is to switch the touch pad with the passenger side one. If the door will still not open it is likely your latch causing the issue. I am suspecting it is a bad latch
Old Jun 4, 2020 | 09:07 PM
Stewie Hibbins
Cruising
Thanks that seems to be the consensus. Curious that it still works on occasion one day then not the next. My car has two names now - Kristina when she’s a sweetheart, Christine (remember the movie) when she’s a bitch!
To C6 driver side door won’t open
