Just know that no matter how fast you think you are, there's always someone faster. Spend 15 large on your rig and there's always someone who's spent 20. Also know that doing more than a little street racing is just dumb. It never ends well. If you're running around with a street hard on, you'd better be on drag radials and hope you don't have to take a curve at speed.
In one of your myriad earlier threads, you mentioned a fun street ride. That's where you need to be. Not chasing your tail trying to keep up with the street warriors.
Stoplight races are won or lost by the time you cross the intersection. It's not as much about the power as it is how quickly and consistently you can put the power to the ground.
It takes a well experienced driver to launch a bone stock Z06 on DR's with a 60' time of 1.70 on a well prepped track.
A base LS3 with nothing more than a $2 shroud prop, a tune, 17" DR's, and a 3600 stall TC can match that.
On the street, the same Z06 is at a disadvantage, since controlling the torque on a poor surface is more difficult with the M6 trans.
If you've never driven a car with a high stall converter, you have no idea how superior the launch makes a difference. No cam, headers, blower, etc can be more effective. It's the ultimate sleeper mod.
BTR Stage 3 cam.....get the whole kit.
Ported and rod-modded LS3 intake.
1 7/8" long-tube headers
3200 stall Yank or Circle-D TC
Gears......in the 3.42 range.
Pat-G (Pat Guerra) tune.....he's in Victoria, so you can have him tune it in person.
KW
Love strong NA stuff also but if you want to spend and really feel a difference put a blower on and be done with it. Throwing a smal cam/headers at it may not give you what youd hope after you spend it all.
Too many crazy fast cars out there, most aare boosted or have 30kplus in mods
If i had to do it all over again Id have built a blower motor. Nice peak #s on a NA engine will still get its butt whooped by a crazy strong torque curve from a supercharger
yes i agree put the Yank PAS 3800 and exhaust and tune and crush those guys in sleeper mode
Love strong NA stuff also but if you want to spend and really feel a difference put a blower on and be done with it. Throwing a smal cam/headers at it may not give you what youd hope after you spend it all. Too many crazy fast cars out there, most aare boosted or have 30kplus in mods
while this is true those guys will only want 60 rolls so true putting a supercharger on it with nothing more than a stall converter would still put you in sleeper mode just with more pop lol remember having a 700rwhp on up rwhp is great especially for bragging rights but honestly most NEVER get the most potntial out of their set ups with out breaking **** and on the street anything over 600rwhp is almost impossible to hook on the street unless your moving already hence the 60 rolls
avoid valvetrain mods and engine mods in general. Try not to open the engine.
A small blower and a converter are two great ways to improve that 0-60 time without touching the engine inside.
From 60+ You would want either a turbocharger or nitrous. A supercharger is not ideal for high rpm or high mph racing (not a small-ish blower anyways)
Honestly I'd be looking at some kind of positive displacement forced induction with (all) exhaust mods (cutout and headers)
with a yank converter
With decent tires and some practice it would rip 0-60 faster than most cars with more power can, people underestimate the force of PD blower on the street... its not like a turbo, the torque is there instantly "surprise"
It's going to cost a lot more than that to beat a Z06.
and what if you have more HP? MMMMM. I just finished up some work and was up for a retune, just so happens they were base lining a 2007 ZO6 garage queen never touched completely stock, pulled 455 RWHP my 2006 LS2 486 RWHP 442 RWTQ, before I did the increase in compression a C& ZO6 jumped me outside Atlanta and he couldn't shake me.
I am no expert but beating the Z06 is a tough order. He has a weight advantage and adding a blower is going to add 100 pounds to the front of the car. If you get a blower, headers, stall, tune and pump up the boost you can complete. But you need good traction 17 inch ZO6 fronts with drag radials.
Was worried that was coming lol. Well atleast hang and not get my but just drug
from a 50 mph roll I pull on a c7 zo6.
....08 Supercharged LS3, speckor works headers, tune, A6 with 2:59 gears. 610 hp at the rear wheels. C6 zo6 is no match for this car.
I have to get some good drag radials to get some traction from a dig though.
I had an 05 Z51 with a small cam (222/230) and ported stock heads and beat multiple STOCK C6 Z06's and 1 stock C6 ZR1 (close race).
I have to agree with above statement I have a PAS 3800 in my car and that converter is just amazing it does need the must effective trany cooler you can get in there but it ain’t that loose at all. Also leave out the turque converter bolts access grommet to help the heat get out. Just heads and cam LS3
I wouldnt run an auto without their unit, the entire build literally revolves around the converter
Yank makes a great budget street converter but they are hardly comparable to an FTI or any of the bolt together billet triple disks many other manufactures make for big power.
although this maybe true FTI and other companys you would think would want to corner the market across the board but when it comes to real street type cars even the ones making up to 1400rwhp Yank, Circle D and PI are top dogs
