Lg headers defect
Old Jun 2, 2020 | 01:48 PM
Marwan's Avatar
Marwan
Default Lg headers defect
Anyone had this problem.
I have a lg headers 1 7/8 only 16 k km in 4 years on them I’ve been hearing some leaks in the driver side headers and I had 2 new codes 171& 174, yesterday I took out the headers removed the heat wrap and noticed a small hole inside one of the 4 pipes, I cut the pipe & saw this, can I just weld the hole and the pice back, will this last ?? Thank u guys .
Old Jun 2, 2020 | 03:48 PM
farmington's Avatar
farmington
Weld it up. Remember it’s stainless. FWIW the header wrap is probably the cause of your problem.
Old Jun 2, 2020 | 09:23 PM
Charliemopic's Avatar
Charliemopic
My 2 cents.
Back in the late 1980s when we started seeing header wrap for automotive use it was said to be for race apps only bcuz back then most car headers were not stainless steel. Plain steel wrapped headers didnt last long on the street.
It was said tubes took a beating under the wrap and sooner than later would eventualy crack.
Nowdays some lit says not to wrap headers tightly.
Old Jun 3, 2020 | 12:42 AM
emoFTW's Avatar
emoFTW
Just get it welded back up. It will be fine.
Old Jun 3, 2020 | 02:25 AM
Marwan's Avatar
Marwan
Thanks for help, I just put it back in place after having it welded,but the guy Who weld it says that this is a factory defect I’m not expert. Hope it lasts.
To Lg headers defect
