Service active handling - no code
Old Jun 6, 2020 | 11:53 AM
SkittlesRgood's Avatar
SkittlesRgood
Default Service active handling - no code
Yep, I'm getting the service active handling warning at random times. I understand the usual causes are the steering wheel position and wheel speed sensors but I'm not getting any codes, so have no idea which part to replace. Hoping someone might know that no code could be a clue to the cause, or maybe my cheap amazon scanners just suck?
These are the two scanners I have.
https://www.amazon.com/gp/product/B011NSX27A/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B011NSX27A/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B071FSNL73/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B071FSNL73/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
2007 base C6 A6.
Old Jun 6, 2020 | 12:32 PM
jamieo's Avatar
jamieo
Have you checked to make sure a plug wire hasn't came loose?Free and easy first step.
Old Jun 6, 2020 | 03:25 PM
torquetube's Avatar
torquetube
Cheap scanners can't see the EBCM (ABS computer), which is where your code is stored. You need to use a Tech 2, or a higher-end scan tool that has support for GM-specific modules.
Old Jun 6, 2020 | 03:50 PM
Dano523's Avatar
Dano523
Yep, need GM Tech II level scanner to pull up the history codes that are are the body level of the car in the BCM.
If getting history DTC's that are pointing back to rear wheel hub sensors as the problem, and the connectors on these are fine/ been cleaned, then would suspect the C186 connector between the side of the battery and passenger fender wall needs to be cleaned since the rear sensor wires run through it.
Old Jun 6, 2020 | 10:34 PM
SkittlesRgood
Gotcha. Thanks a lot guys.
Old Jun 13, 2020 | 07:03 PM
Jimmy 2 Times's Avatar
Jimmy 2 Times
got a pic of that connection?
Old Jun 14, 2020 | 04:57 AM
Dano523's Avatar
Dano523
Number 4 and you have to pull the battery on a wet sump motor to get to it (need to pull the oil tank on a dry sump car).
Old Jun 14, 2020 | 04:51 PM
pyrodav's Avatar
pyrodav
Battery voltage correct?
To Service active handling - no code
