Electrical Concern Trying to start.
Old Jul 19, 2020 | 12:07 PM
rappini's Avatar
rappini
Default Electrical Concern Trying to start.
I was trying to reset the indexing of the windows with the car not running. So I went aux as I was working the aux button dash lights flashed and computer (I think) mad a weird sound, I still couldn't reset the windows so I thought I would start the car and try it that way but all I got was a check engine light and a click. I did a battery boost and it start and the battery register 13.6 the 14,0. Don't understand why it won't start but yet when it comes back it's charged? Any thoughts besides carrying jumper cables and I do carry them.
Old Jul 19, 2020 | 02:30 PM
Bill Dearborn's Avatar
Bill Dearborn
Where did you get the 13.6V, 14V battery measurements? From the instrument panel or a voltmeter applied to the battery terminals. Was that measurement taken with the engine running or off. By the way computers don't make weird sounds. They are totally silent unless they are burning then they make popping, snapping and sizzling noises.
Bill
Old Jul 19, 2020 | 07:28 PM
Rodzilla37's Avatar
Rodzilla37
2nd Gear
Default Default Electrical Concern Trying to start. I was trying to reset the indexing of the
Hi if the battery is good, check your crankshaft sensor, some of the symptoms of a bad crankshaft sensor is the car not starting. Good luck 👍
Old Jul 20, 2020 | 08:51 AM
rappini's Avatar
rappini
Measurement came from the IP with car off, and it was on a Battery Tender at the time. I'm beginning to think that it might be the Ignition switch because when I jumped it nothing happened until I start pushing on the accessory side of the switch, then it started.
Old Jul 23, 2020 | 11:24 AM
rappini's Avatar
rappini
I just put a volt meter on my batt and registered over 14amp but I did a parasidic loss test to find that I'm losing over 3amps not running. So I started pulling fuses and found one that dropped it to .074. it was a 15amp fuse designated RDO/S-Band VICS , radio , S-band VICS I understand the radio but what are the other acronyms? I haven't gone any further I'm wondering if I could just have a bad fuse (I'm not that lucky) I'm sending this to you as you were the only one that gave the most information.
Old Jul 24, 2020 | 11:35 AM
HK770's Avatar
HK770
may help
https://www.google.com/search?q=S-ba...hrome&ie=UTF-8
Old Jul 24, 2020 | 08:01 PM
4SUMERZ's Avatar
4SUMERZ
The VICs acronym is the Vehicle Interface for Communications or the Onstar Module.
The Onstar is one of the main sources for a parasitic draw, as Onstar may try to constanly ping the module to try to connect. Pull the Onstar Fuse and that will most likely fix your parasitic draw.
Old Jul 26, 2020 | 08:36 AM
rappini's Avatar
rappini
Thanks.
Old Jul 26, 2020 | 08:41 AM
rappini's Avatar
rappini
The Radio Sband VICS fuse is the culprit, now would anyone happen to know with Harness/Bundle would apply to that fuse and if I start pulling wiring bundles will I screw up the computer or something else on the car? Other options I'm considering is a battery cut off switch, trading the car in or just disconnedting the battery when when put it away.
Old Jul 26, 2020 | 09:14 AM
4SUMERZ's Avatar
4SUMERZ
I'm fairly certain that the culprit in that circuit is the VCIM (Onstar). Have you pulled the fuse of the Onstar all by itself to see if that is the parasitic draw?
The VCIM module is found at various locations depending on year and model
I have attached a PDF to show where it is located based on your year.
If you want to pull connectors on the VCIM, unplug all of them except the one at J4
That should take the VCIM out of the picture and not F*** up anything else.
Good Luck
File Type: pdf
Old Jul 27, 2020 | 04:05 PM
rappini's Avatar
rappini
I haven't touched the OS fuse but I will do a P draw to make sure. My fuse panel looks diffrerent than the one you show, there is a center bundle on my shaped rectangular with a screw holding it in unless what you show is somewhere else on the car.
I really appreciate the help, thanks again. I'll post up the results.
Old Jul 27, 2020 | 04:09 PM
rappini's Avatar
rappini
I pays sometime to keep reading, I just saw the diagram of where the OS module is thanks for the diagram.
Old Jul 27, 2020 | 06:08 PM
4SUMERZ's Avatar
4SUMERZ
What year is your car?
Old Jul 28, 2020 | 08:55 AM
rappini's Avatar
rappini
2009 LS-3 with NPP.
Old Jul 28, 2020 | 12:10 PM
4SUMERZ's Avatar
4SUMERZ
2009 LS-3 with NPP.
Thanks. The above fuse box schematic should be the same as you car with the Onstar fuse being in that same position.
Old Jul 29, 2020 | 09:14 AM
rappini's Avatar
rappini
I've decided to admit defeat this morning, I'm going to buy a new battery and a battery shut off , just wanted to say thanks for the information.
Old Jul 29, 2020 | 09:24 AM
4SUMERZ's Avatar
4SUMERZ
So, did you ever pull the onstar fuse?
To Electrical Concern Trying to start.
Old Jul 30, 2020 | 09:12 AM
rappini's Avatar
rappini
Yes I did no effect on amps, I might just get a different meter too.
Old Jul 30, 2020 | 12:40 PM
4SUMERZ's Avatar
4SUMERZ
Here is how I checked for a parasitic draw on my C6. See attached PDF
File Type: pdf
Old Jul 31, 2020 | 09:45 AM
rappini's Avatar
rappini
Thanks for that procedure, I picked up a new battery have not installed it yet I'm waiting for a battery disconnect switch. After I put it all together I'll post results.
Thanks again.
