Driver's door latch not working
Old Jul 24, 2020 | 10:31 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
Default Driver's door latch not working
Thank god for the override feature Just bought my first C6 today. I didn't see a thread on this malfunction but I have to believe it's a common failure. What do I need to do to fix it??
Old Jul 25, 2020 | 07:08 AM
DaOtherOne's Avatar
DaOtherOne
You can try this fix or purchase a new switch. A new switch is inexpensive.
https://www.cultragfactoryparts.com/oem-parts/gm-2005-2013-chevrolet-c6-corvette-genuine-gm-exterior-door-release-switch-pad-22751230
https://www.corvetteforum.com/forums...-fix-easy.html
Old Jul 25, 2020 | 09:43 AM
Daffy's Avatar
Daffy
Well that was pretty easy but to no avail. I swapped sides with the switches and my "bad one"works fine on the other side and the good one from the right side doesn't work on the driver's side but it does activate the window, just won't open the door, any ideas?? Could the electric portion of the latch go bad??
Old Jul 25, 2020 | 10:59 AM
DaOtherOne's Avatar
DaOtherOne
I don't know. Maybe someone with more knowledge in this area can help you out.
Old Jul 28, 2020 | 04:44 AM
zaksturbo's Avatar
zaksturbo
3rd Gear
Sounds like the door latch, just had to replace mine on the drivers side. Found it new for around $200, fairly simple to change.
Old Jul 29, 2020 | 05:02 PM
LS14ME2's Avatar
LS14ME2
I had to replace my latch assy on the driver side as well, works a treat now. The hardest part with the install is getting the plastic trim pieces removed without breaking something, just take your time and check out a couple YT vids.
To Driver's door latch not working
