Exhaust drone
Old Aug 3, 2020 | 10:40 AM
Bruce Cole's Avatar
Bruce Cole
4th Gear
Default Exhaust drone
Changed exhaust on mt 2005 now it has a bad drone noise how do i get better sound
we cut the stock mufflers off and put short mufflers on have been told to put straight pipes on to get rid of the drone noise
Old Aug 3, 2020 | 11:39 AM
jrose7004's Avatar
jrose7004
Lots of discussion on the forum and performance exhaust. I've found the Corsa exhaust doesn't have drone. Also the dual mode on my Grand Sport doesn't.
Old Aug 3, 2020 | 01:01 PM
BluegrassMotorsport's Avatar
BluegrassMotorsport
What brand did you buy? Some brands drone much more than others.
Old Aug 3, 2020 | 02:15 PM
Bruce Cole's Avatar
Bruce Cole
4th Gear
we just cut the mufflers off and put a set of short one on i am being told to cut the mufflers off and run straight plpes on it
Old Aug 3, 2020 | 07:00 PM
old motorhead's Avatar
old motorhead
The guy that told you that needs to be shot...multiple times...until he's not moving any more.
Old Aug 3, 2020 | 08:50 PM
Bruce Cole's Avatar
Bruce Cole
4th Gear
what kind of mufflers do you think flowmaster, magnaflow or i know where a set of hooker exhaust axle back is
Old Aug 3, 2020 | 09:10 PM
Withnasty's Avatar
Withnasty
Even if it's the model with the resonator on the cans, the hooker exhaust does drone quite a bit
Old Aug 3, 2020 | 09:40 PM
Bruce Cole's Avatar
Bruce Cole
4th Gear
looks like I just need to go back to something close to the stock muffler
Old Aug 3, 2020 | 10:05 PM
bwill03z's Avatar
bwill03z
Pretty positive if you go straight pipes you are gonna get tons of drone....
Old Aug 3, 2020 | 10:31 PM
BluegrassMotorsport
You were given horrible advise but hey, it happens to all of us eventually. For less drone, I always suggest Corsa. I have the Corsa Sports on mine and even with headers, there is absolutely no drone on the highway. It's so pleasant to drive over long distances but it really wakes up when I give it the gas!
Old Aug 4, 2020 | 11:56 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
what kind of mufflers do you think flowmaster, magnaflow - - -
These tend to drone also.
Old Aug 5, 2020 | 04:51 PM
VolSince69's Avatar
VolSince69
Borla s-type II do not drone either. The newer design (several years old now) appears to be same as Corsa (copy perhaps?). A bit deeper to Corsa’s higher pitch. Both are excellent systems, can’t go wrong with either. Do note: if find original s-type they DO drone at certain lower rpm frequencies.
Old Aug 5, 2020 | 04:59 PM
bwill03z's Avatar
bwill03z
The newer model S type does not drone but I can assure you the older Borla stingers do drone quite a bit
Old Aug 5, 2020 | 05:15 PM
VolSince69's Avatar
VolSince69
Yeah, believe that was the motive for the change from what I've read. Running Type II now with LG headers. Absolutely no drone at any RPM and heavenly at WOT. Love the Corsa sound too, and better tips for sure. That deeper Borla rumble is just my slightly preferred sound. Really was a very tough decision when purchasing - strongly considered both. May change up some day.
Old Aug 5, 2020 | 05:42 PM
MysteryMob's Avatar
MysteryMob
I'm guessing this is the same brilliant person that just chopped off the muffler and welded on some random muffler? Because they clearly don't understand the benefits of an H-pipe or X-pipe, nor should they be giving any sort of advice on anything related to exhausts.
It'd make sense to just buy a quality catback or run stock exhaust with headers.
If you want to get fancy, you could always go with the scientific method of figuring out the frequency of the drone at whatever RPM it occurs at, then calculate the proper length for a Helmholtz resonator and weld it on.
https://wilhelmraceworks.com/blog/killing-drone
Old Aug 8, 2020 | 03:42 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Friend, you have made several good technical comments here. However, expect most or all of them to be ignored.
Old Aug 9, 2020 | 09:05 AM
Marschall67's Avatar
Marschall67
3rd Gear
Depending on what you’re looking for, here’s a little info on some exhaust ,
To Exhaust drone
Old Aug 12, 2020 | 12:53 PM
C6 GS Harbor's Avatar
C6 GS Harbor
Pick up an NPP and an NPP in a box, and let it rip! best of both world IMO.
Old Aug 12, 2020 | 01:11 PM
sstonebreaker's Avatar
sstonebreaker
Sad but true.
Old Aug 14, 2020 | 02:42 PM
Magna_Flow's Avatar
0Magna_Flow
Former Vendor
We agree with the advice in this thread-doing a muffler delete will NOT help the drone issue (probably the opposite). If you were looking for a drone-free solution, we would recommend something like our Street axle back or cat back system. They have a straight-through free flowing design, but won't compromise your interior comfort by being overly noisy/droning. You can find more info about them below on our website. If you have questions about either system, please feel free to shoot us a PM or call at 1-800-990-0905!
https://www.magnaflow.com/collection...xhaust-systems
