Remove Active Handling or Get TPMS Sensors?
Old Aug 31, 2020 | 03:05 PM
limebeard's Avatar
limebeard
Cruising
Default Remove Active Handling or Get TPMS Sensors?
I have a second set of tire/wheels for track days without TPMS sensors. However, when I use them Active Handling (AH) kicks on whenever I take a corner at speed and applies the brakes (here is a good video what happens, posted by another forum member
There are numerous posts on this topic. I am debating between purchasing TPMS sensors for the tires/wheels or removing the AH sensor from the steering column that other forum members have done in the past (here is a more detailed post https://www.corvetteforum.com/forums...-defeated.html).
Does anyone have any experience with this issue? If so, how did you fix it? Has anyone removed the AH sensor? Good or bad results? I also know a few people that have purchased the LG Motorsports TrackBox TPMS Sensor eliminator box, but that's $389 while installing sensors for all four wheels is only $289.
Really appreciate the help!
Old Aug 31, 2020 | 04:24 PM
saplumr's Avatar
saplumr
If tracking the tpm's would be helpful if you have a pressure issue.
Old Sep 2, 2020 | 06:58 AM
limebeard's Avatar
limebeard
Cruising
Anyone else?
Old Sep 2, 2020 | 09:17 PM
jerho1943's Avatar
jerho1943
Cruising
I purchased a track box and it worked for a while. Started having same problem of tpms coming on and having to disable active handling. I would check with LG and the manufacturer, think they told me it does not work over the long haul. Wast of money!
Old Sep 2, 2020 | 09:31 PM
C5 Hardtop's Avatar
C5 Hardtop
I don't quite understand why you need to make these choices, but I'd disable the AH. Just don't drive in the snow, lol.
Old Sep 3, 2020 | 12:40 PM
hawkgfr's Avatar
hawkgfr
TPMS brand new are about 160 per set and last a decade or more...(cheaper can be found but buyer beware)
Old Sep 3, 2020 | 02:27 PM
X-UFO's Avatar
X-UFO
Default Had the same thing happen to me last month
Originally Posted by limebeard
I have a second set of tire/wheels for track days without TPMS sensors. However, when I use them Active Handling (AH) kicks on whenever I take a corner at speed and applies the brakes (here is a good video what happens, posted by another forum member https://youtu.be/4zci9pB6O4c).
I had the Right rear TPMS stop working and the same thing happens, the car automatically brakes on hard cornering. I knew it was the right rear because the tire pressure on the dash "Right Rear "XX". I needed new tires anyway so I got a new TPMS for about $80.00 from the dealer and had it installed with the new tires. Problem solved..
Good luck with however you fix the issue. The tires are not easy to change as I found out from local shops in the mountains of VT.
Old Sep 4, 2020 | 10:56 AM
limebeard's Avatar
limebeard
Cruising
@jerho1943 Thank you! I'll give LG a call.
Old Sep 4, 2020 | 10:58 AM
limebeard's Avatar
limebeard
Cruising
@C5 Hardtop See video above. Without addressing this issue, I cannot track the car with different size wheels or stickier tires
Old Sep 4, 2020 | 11:01 AM
limebeard's Avatar
limebeard
Cruising
@X-UFO appreciate the insight!
Old Sep 4, 2020 | 05:41 PM
C5 Hardtop's Avatar
C5 Hardtop
I saw the first part of the video with the invasive AH, but didn't understand how tire pressure monitoring would have any impact on it.
Old Sep 4, 2020 | 08:35 PM
X-UFO's Avatar
X-UFO
One more thing. I had to bring the car the the dealer after the tire place mounted the tire with the new TPMS. They had to "program" it to the car. I saw them do it and the cars horn honked as they programmed each tire. Just an extra step I had to do to have the system work.
Old Sep 6, 2020 | 10:09 PM
davidfarmer's Avatar
davidfarmer
Just disconnect the steering angle sensor.
Old Sep 10, 2020 | 01:20 PM
limebeard's Avatar
limebeard
Cruising
@davidfarmer That is exactly what I did Now time for VIR this weekend
Old Sep 10, 2020 | 01:25 PM
limebeard's Avatar
limebeard
Cruising
@C5 Hardtop If you don't have TPMS sensors in your wheels (which I don't for my track wheels), then the car automatically kicks on AH too early and won't allow you to turn AH/TC off using the center console button. Thus, I would either have to buy additional TPMS sensors for all my track day wheels ($$), buy a LG Motorsports track day box ($$$), or pull the steering angle sensor from the steering wheel column (no cost).
I've pulled the sensor and am ready for VIR this weekend
Old Sep 18, 2020 | 05:48 PM
AFRob's Avatar
AFRob
That looks like almost exactly what I experienced last month at Portland.
My instructor had me switch to competitive mode. It helped a ton. I'm still slow, but it allowed more slip angle.
I was too chicken to turn everything off.
Rob
To Remove Active Handling or Get TPMS Sensors?
