2013 corvette project
Old Aug 31, 2020 | 09:37 PM
Xaxo Vazquez's Avatar
Xaxo Vazquez
3rd Gear
Default 2013 corvette project
I got 2013 corvette 6.2 ls3 engine I have understand so my block is over is cracked so I find lsx engine block my question. Is if can I installer the head for ls3 in lsx blck engine
Old Aug 31, 2020 | 09:42 PM
FX VETTE's Avatar
FX VETTE
Welcome to the CF! Check out the C6 section
Old Aug 31, 2020 | 09:54 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum, Xaxo!
As FX VETTE recommended, you can probably get really good info in the C6 sections.
One question will be the bore size. At one time, I believe the LSX block came out of the foundery with a 3.880" bore.
Of course, the LS3 head is designed for a 4.00" or larger bore, so you would have to know for sure the size bore on your LSX block (or be ready to increase the bore up to the 4" minimum)..
Again, the C6 members I'm sure will have much more up to date info.
Best wishes with your build!
Old Aug 31, 2020 | 10:07 PM
Moved to C6 Tech.
To 2013 corvette project
