C6 Base Steering Rack Fitting Help...
Old Sep 27, 2020 | 08:10 PM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default C6 Base Steering Rack Fitting Help...
Does anyone know if the fitting under the harmonic balancer can be removed and replaced? There is no hex to grab it with a wrench. I am hoping I don't have to replace the whole rack for a stupid buggered up fitting.
Thanks is advance. If it matters 2008 Base, Z51
Old Sep 28, 2020 | 09:42 AM
Mudpie1313's Avatar
Mudpie1313
Looks like the fitting is a piece of the housing.
Old Sep 28, 2020 | 11:08 AM
Dutch08's Avatar
Dutch08
Looks like the threads are OK. Maybe adapter fitting of some type with thread sealer?
Old Sep 28, 2020 | 11:17 AM
Rob 93ZR-1's Avatar
Rob 93ZR-1
Originally Posted by dutch08
looks like the threads are ok. Maybe adapter fitting of some type with thread sealer?
FREAKING BRILLIANT!!!!
Thank you!!!
Old Sep 28, 2020 | 01:28 PM
Mudpie1313's Avatar
Mudpie1313
that is a JIC style fitting. If it meets with pressure, the sealing stuff you put on the threads will still leak, but not as badly. The tapered end seats inside a concave in the hose. Take Emory cloth and smooth any high spots from the taper. Hopefully that will help it seal.
Old Sep 28, 2020 | 01:55 PM
Dutch08's Avatar
Dutch08
Thanks to Mudpie1313 and google I now know what a JIC fitting is. I would definitely follow his advice. Let me add on a hydraulic fitting it is my understanding you should use Hydraulic Sealant on the threads, not Teflon tape.
To C6 Base Steering Rack Fitting Help...
