Pedal Commander
See Soler throttle controller and Vitesse throttle controller.
FWIW - I'm currently running a Vitesse, but if I were buying new today it would probably be the Solar simply because it's inexpensive. After playing with the various settings and finding what I liked I leave it there. It's been at least a year since I last played with the settings.
YMMV
As far as the pedal commander, I would either go with the Vitesse or Soler throttle controllers. The pedal commander does not have a setting that is a true 1:1 ratio between the pedal and throttle, while those do.
Anyone who drives their car on track will attest to this. racers want a truly linear throttle. The only C6s I ever drove on track are my Z06 and a friend's C6 ZR1 ...neither had any throttle lag. But both were overly acute. Perhaps other models do lag...I don't know.
Drag racers, will disagree of course
In fact, most modern automatical cars with a sport mode (besides choosing lower gears and holding them longer before an upshift), really only eliminate some annoying throttle lag and just create an artificial sense of more power by opening the throttle in a non linear fashion.
I had one of these devices plugged in behind the throttle of another car (Porsche Cayenne S ...tow vehicle), solely to eliminate a terrible 1 second throttle lag. But, it also affected fuel economy slightly.
Anyhow, another thing a real tune can do is to reduce the delay when shutting the throttle, thereby making down shift heel and toe rev matching easier than it is with the throttle hanging open a moment.
Oh...how I miss a good ol' throttle cable...one without an 'artificial' cam on the bellcrank to make it appear that the car has more oomph
The first thing a throttle controller allows you to do is create a more liner throttle response, which is exactly what your posts suggests is the best course of action. But then you head off on some tangent about how that's bad when a TC does it and should only be done with a tune. But what the hell do I know. I've only ever won two SCCA National Championships so I'm probably talking out my ***.
Bottom line most street drivers will discover a throttle controller makes their car a lot more fun to drive and in the end that's all the large majority of forum members desire.
Whereas a plug in TC did not, on a another (albeit street only driven) vehicle. All it did was emulate an already existing sport mode setting by taking out some annoying delay but making the throttle too acute. It was wasted $$ and ultimately, a tune rectified that too.. I threw that TC away
That's my experience, so, I feel investing in a tune is a better solution. That's all.
BTW, congrats on those SCCA Championships!
