New owner question
Old Oct 24, 2020 | 11:00 PM
wcdknows's Avatar
wcdknows
Default New owner question
After being away from corvettes for a while, just wondering what realistic wheel hp gains are on a 05 with headers(speed engineering and CAI). Just looking for fun 1/4 runs here and there.
Old Oct 25, 2020 | 03:09 AM
Dano523's Avatar
Dano523
Long tube headers will pick up about 25hp due to better scavenaging of exhuast gases pulled from the heads, while tune from OEM to the one needed for the headers, will pick up about another 15hp itself.
CAI does not pick up horsepower, but keeps you from loosing it, if the engine is taking in hot air to cause it to retard the spark instead. So on that note, make sure that the system you are going to install, it picking the air from outside the car, and not still from the engine bay area like the OEM system.
As for retune from OEM tune, it's not really the added Hp that makes a huge difference, but turning off torque management in the OEM tune that is holding back a lot of instant power from reaching the ground instead. Hence just turning off TM and running slick, will make a bigger difference then the added 40'ish horsepower your going to pick up and use on the back end of the strip after the launch (since launch is your biggest hurdle to start with, hence not blowing up the drive line out of the hole).
