Header question
Old Nov 15, 2020 | 04:06 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Originally Posted by 3X2
My preference is ARH. These seem to make the most power on the dyno. Whatever brand you choose, here a few things I do when installing headers. Some may not be needed.
1- wrap the starter housing and solenoid.
2- use metallic heat shield (i.e. DEI) on the primary tubes closest to the starter and oil cooler pipes, secure with metal self locking band straps. It comes in sheets, cut as needed with tin snips.
3- I cut the tunnel plate into 2 pieces right where there is a notch in the tunnel, between the 4th and 5th bolt, and notch one side of the plate then run the O2 wires up in between the tunnel plate and torque tube.
4- fire sleeve the O2 connectors and secure as far away from the headers as possible with wire ties.
5- fire sleeve the 2 trans cooler pipes where they go over the right side header collector.
6- wrap the right side header collector at the trans cooler pipe area, see #2.
7- fire sleeve the 2 heater hoses.
8- add additional fire sleeve to the wire harness behind #8 primary tube.
9- add a small piece of fire sleeve over the purple wire and connector on the starter solenoid.
10- rotate the knock sensors as needed for additional clearance and secure wiring with wire ties.
11- fire sleeve the clutch slave cylinder line.
12- depending on header brand, heat shield #7 primary tube if close to slave cylinder line.
13- add heat boots to the plug wires and secure the coil end with wire ties.
14- if not already there, fire sleeve the engine mounts.
15- use high temp antisieze on all the bolts and the oxygen sensors.
16- no header wrap. I also have had high temp coatings peel off. may work ok for a street car.
17- check for clearance between the chassis flange and where the 4 tubes join the collectors on both sides. Depending on header brand, I have had to bend the chassis flanges with a hammer. Not required on aluminum frame cars.
Good grief! I installed LG Motorsports long tube headers 2 years ago and didn't have to do all of this stuff! NO problems!
I did add the cool socks for the plug wires but I doubt they were needed.
The LGs fit perfect and were easy to install. I did it on jack stands in my garage.
Tom
Old Nov 15, 2020 | 07:03 PM
3X2's Avatar
3X2
Tom
To each his own. P:lease reread sentence number 4. I've done dozen upon dozen header installs on C5-7's and fixed numerous issues on headers installed by other people from melted slave cylinder hoses, melted 02 connectors, burned wiring harnesses etc. Doesn't matter the brand. ARH, Kooks, LG, Texas Speed, Pfadt, Billy Boat, Wheel to Wheel and on and on. You may be fine on a street car which doesn't generate the heat that the track day and race car Corvettes we build do. That's good, but even a street car header install I do gets these same things done.
Old Nov 15, 2020 | 09:18 PM
Hawkdriver's Avatar
Hawkdriver
Originally Posted by Z97
They look visually easy to do from top side of the car. You dry sump or not?
Mine is a wet sump. GS Vert with auto. You might be able to do from top
Old Nov 20, 2020 | 09:29 PM
bwill03z's Avatar
bwill03z
Originally Posted by Turbo6TA
My bone stock 2011 GS / LS3 with automatic trans: 371 RWHP on the Dynojet
Added 1 3/4" headers with cats and a dyno tune: 405 RWHP on the same Dynojet
Gain of 34 RWHP
Thats a nice gain especially for the 1 3/4 headers. Which ones did u go with and why not 1 7/8?
