Control Arm Install
Old Nov 10, 2020 | 10:22 PM
GS_DAN's Avatar
GS_DAN
Default Control Arm Install
Hey Corvette Forum,
I plan to install Delrin control arm bushings this winter. While there are plenty of threads and videos of installing the bushings themselves, I can't find very much information on removing and re-installing the control arms themselves. Is it pretty straight forward? Worth attempting for a somewhat novice wrencher on jack stands? (was a lube-tech in college and have installed simple bolt-ons on this car). I have seen one video on youtube covering a C5 which is probably similar but have read some odd issues here on corvette forum. Saw someone needed to remove exhaust manifold or cut out a front upper control arm bolt, C6zs have some collar you have to cut off. Have a friend with a hydraulic press that can assist with the bushing install so not too worried about that part.
I am looking to see if anybody has a write-up on the r&r of the control arms for a C6 corvette or can give any tips/advice on issues they ran into.
Thanks in advance, look forward to hitting the track more in 2021.
Old Nov 11, 2020 | 06:29 PM
Dane@LGmotorsports's Avatar
Dane@LGmotorsports
Premium Supporting Vendor
Originally Posted by GS_DAN
Hey Corvette Forum,
Biggest PITA is separating the ball joints from the spindle. Heat is your best friend on that one just be careful not to burn the boots when heating up the spindle.
Old Nov 12, 2020 | 02:25 AM
Dano523's Avatar
Dano523
Front upper control arms.
When you remove the bolts that hold them to the inner fender wall/frame brackets, going to find washers (spacer stacks) stacked between the rod ends and the fender inner wall as you remove the bolts. Keep the washer stacked together per location, and make where they go back in in the same spots when you are reinstalliing the upper front A arms back.
Old Nov 12, 2020 | 09:47 AM
GS_DAN's Avatar
GS_DAN
Thank you! would not have thought of using heat and forgot about the alignment washers.
Old Jan 13, 2021 | 02:20 PM
GS_DAN's Avatar
GS_DAN
What are people using on the axle splines when re-installing? Cannot find a clear answer. Small amout of axle grease? White Lithium? Dry? Never had any clicking, just want to re-install correctly.
Old Jan 13, 2021 | 03:05 PM
drewz06's Avatar
drewz06
thing knower
i did this by the manual and it did not mention any sort of lube on the splines....
its fairly straight forward as you'd think.... i found there were 4x washers per each UCA on my z06...
i swapped out my eccentrics with the amt camber kit... really killer stuff!!
-drew
Old Jan 14, 2021 | 01:58 PM
chevyjeff's Avatar
chevyjeff
get you one of these from harbor frieght. will save you time and cuss words seaperating the ball joints from spindle
Old Jan 14, 2021 | 02:35 PM
GS_DAN's Avatar
GS_DAN
Getting it all back together now. I could not for the life of me get that thing to open wide enough, for the lowers at least. Got them free with a different tool with teeth to grab onto the ball joint and not interfere with the boot.
Old Jan 14, 2021 | 02:37 PM
drewz06's Avatar
drewz06
thing knower
yeah i just ordered an air hammer off the `zon to do the lowers in the future...
Old Jan 14, 2021 | 03:14 PM
chevyjeff's Avatar
chevyjeff
i had same issue
i put the tools "finger" on the top of one of the sides of the the ball joint nut that was unscrewed about 1/8" above control arm surface.
both lowers front and back popped loose that way
Old Jan 14, 2021 | 10:08 PM
PCMusicGuy's Avatar
PCMusicGuy
Yes, those tools suck a lot. I tried the rental tool at Autozone and it was also a failure. If I ever have to do this again I will buy the GM tool or one just like it. Luckily for me, I was replacing my control arms and spindles with new so I used a bug hammer and a pickle fork.
Please let us know how you like the Delrin bushings after driving for a while. Whose are they?
Old Jan 15, 2021 | 03:12 AM
jw1's Avatar
jw1
I have a similar ball joint popper to the one pictured above and it works fine for the uppers, but not wide enough for the lowers. Just ordered another one for ~$60 that should fit. Will post up when I get it next week.
Old Jan 15, 2021 | 11:29 AM
Zapp Brannigan's Avatar
Zapp Brannigan
Don't make the ball joint tool do all the work. Put it under pressure and then smack it with a hammer and it will pop apart.
Old Jan 15, 2021 | 12:10 PM
GS_DAN's Avatar
GS_DAN
Installing the Borg Delrin 100AF bushings. Hoping to get it back together this weekend and aligned Monday.
Old Jan 15, 2021 | 04:29 PM
Borg Motorsports's Avatar
Borg Motorsports
Supporting Vendor
Thanks for the support! Shoot me an email or give me a call if you have any questions during the install.
__________________
Borg Motorsports
www.borgmotorsports.com
Lane Borg - Owner
lane@borgmotorsports.com
2012 AS Solo National Champion
2014 BS ProSolo and Solo National Champion
Old Jan 15, 2021 | 07:27 PM
tw78911sc's Avatar
tw78911sc
I ground off the tip of the pivot arm on the tool so it could open up more and opened up the mouth of the tool, works like a champ now,
Old Jan 19, 2021 | 02:41 PM
jw1's Avatar
jw1
I tried that, but it didn't work for me. This is what I used to pop the LCA ball joints.
To Control Arm Install
Old Jan 19, 2021 | 04:14 PM
GS_DAN's Avatar
GS_DAN
That thing is a monster, would for sure get that if i need to take them off again in the future.
Old Jan 19, 2021 | 04:26 PM
GS_DAN's Avatar
GS_DAN
Completed the install over the weekend and had it aligned today. Overall was not too bad if you take your time (And don't snap an eccentric bolt).
I went with the Borg Motorsports 100AF Premium Delrin bushings. I use the car for Autocross and HPDE, still a beginner, and about 50% of the time on the street. I've only driven it a couple of days now but so far the ride feels so much better. I have noticed ZERO increase in NVH (Noise, vibration, harshness). Not a single squeak. The car just feels more crisp and firm; more connected to the road. You can feel small cracks or reflectors in the road more, but not in a harsh way. My old bushings were not shot in anyway, I've just been eyeing these for a while and with the Black Friday deal, I couldn't pass them up. I would recommend these to any C5/6/7 owners, not just those who intend to track their car.
Removed one washer from each dog-bone bolt and was able to achieve -2.3 degrees F and -1.3 R camber and went with a smidge toe in in the front, zero in the rear.
Old Jan 19, 2021 | 05:28 PM
Borg Motorsports
Supporting Vendor
Thanks for the great feedback! Glad you like them!
