Transmission gear changes
Old Nov 19, 2020 | 05:51 PM
JeremyAZ's Avatar
JeremyAZ
Default Transmission gear changes
Has anyone swapped gears to a different ratio in the TR-6060?
Wanting to swap my GS 1,2,3 to ZR1 1,2,3.
GS gearing is much too short when higher HP. Then the 3-4 is a 1800rpm drop so you are out of good boost because the 1,2,3 are so short.
Is it a direct swap since they are just different ratios in the same trans?
thanks.
