Happy thanksgiving to you guys!
Ran into a issue of having open headers as I receive new parts. However this morning I went to move my car and unfortunately the clutch pedal just dropped. There was a leakage but I couldn’t see any lines torn? Anyone have some relative issues they can assist?
also I see the master cylinder above but where is the clutch cylinder ?
See if you can find where it leaked. If its the mastercylinder leaking, you can picked under the dash where there shaft for the clutch pedal goes thru the fire wall. If its wet, then its your master cylinder leaking. Also double check your reservoir and verify if it went dry or not.
