Clutch issue???
Old Nov 29, 2020 | 07:02 PM
Ridndirty1000's Avatar
Ridndirty1000
Cruising
Default Clutch issue???
I bought a 06 corvette the car has an rpm tr6060 and has an mccleod rxt clutch. When I release the clutch pedal slow it is perfect no noises, when I release it fast it make a squeak noise like metal on metal. The clutch does not slip at all. I put in 4th gear low rpm and it did not slip. From what I am reading it sounds like a pilot bearing or the throw out/ release bearing... any help please! The driveshaft was also changed not sure if that has anything to do with it... thanks
Old Dec 1, 2020 | 11:39 AM
Dutch08's Avatar
Dutch08
Hard tell the actual problem. I did have the same issue and when I pulled the clutch the pilot bearing was going out. A new pilot bearing later the noise was gone. (**I did replace the clutch/flywheel/slave as well)
Old Dec 1, 2020 | 05:40 PM
Spaceme1117's Avatar
Spaceme1117
Regardless, the only way to know for sure is the drop the torque tube/trans/diff. Would have to do that anyway to change out the pilot bearing.
Old Dec 1, 2020 | 05:45 PM
Ridndirty1000
Cruising
Well good news/bad news. I called McLeod they stated this sometimes this happens it is the disk. They said it will not cause a problem. So I guess I’m just stuck with that annoying noise for awhile.
To Clutch issue???
