Fitment
How dare you suggest he call the MFG. what a horrible thing too tell the guy. you should be banned for life, I know people who have been banned for less! Don't you know your supposed to do the research for him and then suggest alternatives and do some pricing and find reputable shops in his area that would do the work reasonably, How inconsiderate could you be?
That package you posted a link to also contains an LS3 rectangular port intake manifold ... You don't need any intake manifold since the Heartbeat SC replaces the intake manifold.
The package also contains a camshaft, but if you really want to change out your stock cam for something bigger, you need to look for a grind that works best with a positive displacement SC (the Heartbeat is a positive displacement SC). That cam in the package is designed to work best for engines that are not supercharged.
Bottom line ... All you need is a set of rectangular port LS3 heads to mate-up correctly with the Heartbeat SC ... And if you want to change cams, pick a cam from someone like Cam Motion that is designed for folks using a positive displacement SC.
And to save you even more money, get a set of stock LS3 heads instead of expensive aftermarket LS3 style heads ... At the power level you will be running, aftermarket heads is not a great 'bang for the buck'.
Fuel rails and injectors will be supplied with the Heartbeat kit,
________________________________________ __
So .. To recap .. All you need is a set of stock LS3 heads and the Heartbeat SC kit designed for the LS3
Good luck ...
Don't forget to get a good harmonic balancer such as the PowerBond 'Race Performance' Harmonic Balancer (P/N: PB1117SS) to replace the failure prone OEM balancer.
This balancer will need to be pinned because of the SC you will be installing ... The pinning kit is supplied with the Heartbeat kit, so you don't need to buy the pinning kit separately.
A dyno tune is much better than using the tune that comes with the SC.
So, if you plan on having the car dyno tuned, save an extra $200 by purchasing the SC kit without the supplied tune.
https://gwatneyperformance.com/cart-share/knNLJ/ref/3/
Please let me know what you think. I hope to have approximately 600 rwhp. The other route I am considering is either a cartek NA set up or a Mamo ls3 NA set up. They are all kind of in the same ball park. cartek least expensive as they would work my existing heads but I know their set ups work. HB set up probably cost the most but i dont mind if the end result is worth it.Feel free as to which route would be best for a weekend cruiser, I dont mind it being aggressive but don't want a strictly drag car either. I will definitely buy a balancer too. Old motor head would I need a boost a pump or fuel system upgrade for hb and what pulley should I run if I go that route.
To hit 600 with a Heartbeat blower on top, you'll need an 87mm blower pulley and a mild blower cam along with long tube headers and a free flowing exhaust. That's assuming you have an M6 transmission. You'll need to go down another pulley size to hit 600 through an A6 transmission. You'll need a boost-a-pump and a bigger set of injectors too. If you did a flex fuel conversion, you could probably hit your goals with the stock cam. I've done 4 TVS2300 builds. If I happen to lose my mind again and put another one together, it would employ flex fuel.
It made 535 RWHP @ 6,300 revs using a 93MM drive pulley and a set of 1 3/4" headers with cats (everything else stock to include stock heads and cam)
535 RWHP = 623 Net crank HP figuring a parasitic HP loss of 14% through the A6 transmission drivetrain
At that HP level, it did not need a BAP or bigger injectors than the LS9 injectors that are supplied with the Magnuson 'Heartbeat' kit.
