2013 427 Plug Wires Fall Off
Old Dec 10, 2020 | 06:01 PM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
Default 2013 427 Plug Wires Fall Off
2013 LS7 427. I had plug wire #1 fall off the coil and replaced it about 6 years ago and it never has given me another problem I recently had #3 fall off and have replaced that 2 times now. The fist time I probably broke the clip when trying to push it on. Replaced that and the new replacement has come off 3 times so far, no broken pieces. These are all OEM's. I'm considering going to something else. Has anyone had this issue and what was done to correct (and or what wires did you go to if not OEM's). I heard that some of these had issues of falling off the coils. Thanks, Tom
Old Dec 10, 2020 | 09:45 PM
Todds427's Avatar
Todds427
St. Jude Donor '12
Its a fairly common problem with these engines. Plug wires falls off and you get misfire. I would think new wires would help. Try something besides OEM wires.
Old Dec 10, 2020 | 10:13 PM
gsflyer2011's Avatar
gsflyer2011
Yes. Try msd wires. They have excellent connectors, will never come loose like the cheap OEM Mexico made ones. Take a look at your connectors than look at msd. Mega difference.
Old Dec 11, 2020 | 05:52 AM
Spaceme1117's Avatar
Spaceme1117
Had this happen on my GS the day after I brought the car home. Very common.
I bought a set of Summit Racing wires and never have had this problem again.
Old Dec 11, 2020 | 12:17 PM
old motorhead's Avatar
old motorhead
Or, if you're cheap like me, take a set of pliers and crimp the spark plug end just a bit. I've never had a "coil end" come off. After the crimp job, never had a spark plug end come off again either.
Old Dec 11, 2020 | 04:14 PM
tomringo's Avatar
tomringo
What plugs are you all using, I was planning to replace with the OEM's.
Thanks again for all the information
Old Dec 11, 2020 | 09:29 PM
gsflyer2011
The metal oem uses is paper thin. It even breaks all by itself. You crimp it and as soon as you slide it over the spark plug end it looses its crimp and becomes loose again.
Old Dec 12, 2020 | 11:42 AM
3X2's Avatar
3X2
I wire tie them to the coils
Old Dec 12, 2020 | 02:21 PM
mikecronis's Avatar
mikecronis
I bought Magnecore wires and those kept falling off too. Moved to Edelbrock's X-Fire and those are a complete shroud-kit and work great and haven't had a problem since.
Old Dec 13, 2020 | 12:31 PM
grpweld's Avatar
grpweld
These have worked really well for me and definitely aren't going to fall off https://www.summitracing.com/parts/SUM-887828
Old Dec 13, 2020 | 12:42 PM
Spaceme1117
I have these also. I like that the spark plug boot has a lot more surface area to grab onto. Makes plug wire removal much easier and less prone to ripping the wire out the boot.
Old Dec 13, 2020 | 03:52 PM
JetstreamGS's Avatar
JetstreamGS
Firecore50 with the promod boots if you have headers. Best wire money can buy.
Old Dec 21, 2020 | 07:24 PM
tomringo's Avatar
tomringo
I did try that with the one that kept falling off!
To 2013 427 Plug Wires Fall Off
