Dry Sump Diagram Needed
Old Jan 4, 2021 | 12:46 PM
1991Z07's Avatar
1991Z07
Default Dry Sump Diagram Needed
I'm putting together a dry-sump LS3 for the track car, and was looking for a diagram for hose routing, check valves, etc. so I make sure I get all the parts & pieces needed to make this work.
I've seen some partial ones...and (of course) people like Aviad have diagrams but it's for THEIR multi-stage systems.
Just for reference: this is getting installed into a C4 ZR1 chassis...so all bets are off on anything being "standard" or stock.
It's an HPR468 (LS3 block, LS7 heads, ZR1 dry-sump pump)...
Thanks in advance...
Old Jan 7, 2021 | 05:44 PM
3X2's Avatar
3X2
Who is the manufacturer of your dry sump?
Old Jan 7, 2021 | 06:49 PM
jft69z's Avatar
jft69z
There's some good info here, with a couple of part numbers listed under the 'Oil System':
https://www.chevrolet.com/content/dam/chevrolet/na/us/english/index/performance/resources/installation-guides/crate-engines/01-images/ls9-installation-guide-19260165.pdf
https://paceperformance.com/files/pdf/LS9.pdf
https://www.chevrolet.com/performance/engine-components/ls-lt-lsx-series-blocks/dry-sump-components
To Dry Sump Diagram Needed
