Help - C6 won't start
Old Jan 4, 2021 | 02:46 PM
Te-Dub's Avatar
Te-Dub
3rd Gear
Default Help - C6 won't start
I have a 2009 C6 that has a gremlin of some sort. Checked my battery and it was dead. Just installed a new battery. All the power items come on...lights, radio, fan, bells. But when I hit the ignition button nothing happens. No clicking, does not turn over, no sound at all...Crickets...Nada! All of the power items go away for about 10 seconds and then come back on again.
Thoughts on what the issue may be and any suggestions are greatly appreciated.
Thanks,
T
Old Jan 4, 2021 | 08:59 PM
Dano523's Avatar
Dano523
What trans, hence if M6, do you have the clutch pedal pushed all the way down to activate the bottom clutch switch.
If A6, do you have your foot on the brake pedal to activate the brake switch, and is the car in park.
Note here, if you are pressing the brake pedal hard, then push up on the shifter in part towards the dash, since it may be the micro switch lever that needs to be tweaked.
Also, make sure that the DIC is not stating Fob not found as the main problem isntead.
Bottom line, Tech II helps to check the above switches to make sure they are working correctly in the first place, Do a BPS relearn if needed, to weed out other problem like the starter relay not working, or even starter solenoid terminal bolt loose/terminal broken off, or just bad starter solenoid in the first place.
Hence a simple test if starter will not fire and turen, is to put the car in neutral with the E brake on, do the starter button push to begin with to put the car in run mode, then pull the starter relay in the engine fuse box, jump the fuse block for the starter relay and see if the car starts. If it does, then either bad relay that is easy to test, but tells you that everything down line of the relay is fine, and its just the BCM that is not sending the start command to fire the starter relay in the first place. Hence problem back up line that the BCM is checking those sensor, before it will send the start command to fire the starter relay.
Old Jan 5, 2021 | 09:47 AM
pcguy2u's Avatar
pcguy2u
Very likely there is a code that needs to be read... Or, one of the battery cable terminals needs to be cleaned.
To Help - C6 won't start
