Misfires under load
Old Jan 9, 2021 | 09:01 AM
Richi's Avatar
Richi
Default Misfires under load
Hi,
I have a lot of misfires under load
The O2 sensor was bad (stuck at 1048mv) so I changed it yesterday and now it is working
However I still have the misfires whent at WOT
Any Idea ? Do I have to drive the car to reset the ECU value ?
Regards
Richard
Old Jan 9, 2021 | 10:07 AM
helga203's Avatar
helga203
Originally Posted by Richi
Hi,
Regards
Richard
Did this just start out of the blue ?? Or did you do any work on the engine ??
Old Jan 9, 2021 | 10:09 AM
NYC6's Avatar
NYC6
Check your plug gaps and coil wire connections
Old Jan 9, 2021 | 10:18 AM
Richi's Avatar
Richi
I did a clutch replacement
The O2 sensor connector was not fitting properly after that so I had to change the entire O2 sensor (car has 70k miles)
I hhad a P0300 and P0134 code
The plugs are brand new, the plug wires also
I swapped the passenger side coils with the driver side coils but same problem
Misfires are mainly located on the driver side cylinders
Old Jan 9, 2021 | 11:50 AM
helga203's Avatar
helga203
Did you remove or take off passenger side header?? If so did you take out plugs??
Old Jan 9, 2021 | 12:40 PM
Richi's Avatar
Richi
Yes I did and yes I removed the plugs
Old Jan 9, 2021 | 02:46 PM
helga203's Avatar
helga203
I've seen hair line cracks on spark plugs and maybe a spark plugs wire got damaged, seen that also. Ohm out the wire. I'm just tossing so ideas out there. Never know. Just trying to eliminate.
o another thing is take out all the spark plugs and make sure none are fouled out or soaked with gas.
Old Jan 9, 2021 | 04:29 PM
Richi's Avatar
Richi
I will double check them so
concerning the O2 sensor, do I have to drive few days for the ECU for the calibration ?
Old Jan 9, 2021 | 04:45 PM
old motorhead's Avatar
old motorhead
What spark plugs are you using?
Richi's Avatar
Richi
Ngk tr5ixUsing them for 3 years without any problem
Old Jan 9, 2021 | 06:33 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What do you mean by ECU “calibration” or value ???
Old Jan 9, 2021 | 06:38 PM
old motorhead
I've had bad NGK plugs right out of the box. Similar issues to what you're having. If connections are good at the plug and at the coil, you might try another set of plugs. Mine ran fine until I got into boost. Then, it starting with random misfires. I pulled them for inspection and they looked good. Never set a code, but I didn't run them long before going back to AC Delco's one notch colder than stock LS3. Same plugs as used on Z06's and ZR1's. Check everything as mentioned above. If all checks out, find another set of plugs to try. Even the ones you pulled out if they're still around and not fouled.
Old Jan 12, 2021 | 09:21 PM
Richi's Avatar
Richi
Well it was a bad spark plug...
I changed them 500 kms ago but well, problem solved
Thanks to everyone
Old Jan 13, 2021 | 02:12 PM
helga203's Avatar
helga203
Thanks to everyone
glad you got it and thanks for the update 👍
To Misfires under load
