Alignment and wheel size
Old Jan 11, 2021 | 10:39 AM
twa1457's Avatar
twa1457
Default Alignment and wheel size
I have a 2006 C6 with 19" frt wheels & 20" Rear. If I go back to 18" & 19"'s will it change alignment?
Old Jan 11, 2021 | 11:18 AM
Nowanker's Avatar
Nowanker
Pro Mechanic
No...
Alignment angles are adjusted to the chassis, with the exception of caster which is measured relative to level.
Changes in relative diameters F to R will (technically...) change those readings due to the change in rake of the car.
Not likely to be significant or even noticeable in any way.
If angles haven't been checked in a while, it wouldn't hurt to have an alignment done.
I always recommend a performance shop over the standard gas station/tire shop for the work. It's usually worth the extra cash.
Old Jan 11, 2021 | 11:43 AM
twa1457's Avatar
twa1457
Many thanks, you guys are great!
To Alignment and wheel size
