Powerbond balancer
Old Jan 19, 2021 | 12:37 AM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Powerbond balancer
I am doing a cam upgrade and all the goodies. My OEM Balancer has the little seal on the inside of the balancer. I am replacing with Powerbond and would like to know if that seal is needed on the new balancer ? I think I read along time ago to not use that seal.
Old Jan 19, 2021 | 09:44 AM
Last 1's Avatar
Last 1
It a friction washer I would say throw it away. You are talking about the washer between the balancer and oil pump ?
Old Jan 19, 2021 | 10:09 AM
2008 Corvette
Default Power Bond
Yes I am. Thank You. Any other replies welcome also.
Old Jan 19, 2021 | 04:41 PM
chevyjeff's Avatar
chevyjeff
if your crank and balancer are keyed you don't need it.
think its to help prevent the factory balancer from spinning on the crank (no key)
Old Jan 19, 2021 | 08:11 PM
2008 Corvette
Default Balancer
An OEM LS3 Crank and Balancer are NOT keyed. Powerbond balancer has a key way that will be filled carefully with sealant when installing and I am pinning the balancer. Don’t need a think, need a definitive answer. Thanks. Have a call in to Dayco. Dayco returned my call this AM and said to reuse the friction washer.
Old Jan 20, 2021 | 09:51 AM
2008 Corvette
Dayco says to use it. Helps with proper spacing.
Old Jan 21, 2021 | 06:52 AM
Spaceme1117's Avatar
Spaceme1117
Good idea to replace the seal for the balancer that is on the timing cover.
Old Jan 21, 2021 | 09:24 AM
2008 Corvette
Default Balancer
Yes, I know that and I am doing that also. Found a lobe on the OEM cam with rough spot on the aperture. Replacing lifters with LS7 performance and new GM lifter trays. Thanks.
To Powerbond balancer
