I just want to thank you all for the spirited input. Lol!
With that being said, anybody want to list all the "maintenance" you would perform while i change the HB out for the second time.....
Thank you in advance!
if your power steering hoses is old and seeping, that will be good time to replace when you have lots of room to replace it. Same goes for A/C tensioner. I didn’t replace mine since it was really good shape when I did mine last week.
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Originally Posted by fdmech1
How do you drop the cradle to the floor without removing the p/s pump to rack line????
You don't need to disconnect anything to do with the PS lines as there's enough slack so that you can drop everything down together. You do however need to remove the single bolt holding the steering shaft to the pump.
Dropping the rack is so much easier than draining the rack and disconnecting the flare but fitting etc. I know this is an old thread but man I would drop the subframe for sure over the other method. I just did this and it really is not that bad.
