I have coilovers and I noticed that the front sway bar is hitting the spring. Are there any aftermarket sway bars that give that extra 1/4" (hopefully more) clearance?
I'll check into the lower shock mount moving rearward a little. I mounted it centered so it didn't touch the upper control arm. I'll also take a look at grinding the end of the sway bar a little.
Maybe both of those together may solve the problem.
I'm not sure about smaller diameter coils. Not sure where to get those and if they will fit Ridetech?
I have 2.25" springs and have used T1 and Hellwig bars with no issues. If I had your issue I would look to break out the grinder to see if I could fix it.
I put on the eFe adjustable end links and was able to adjust them up and they cleared the coil. I was surprised that one side needed adjusting an additional almost 1/4" to unbind the swaybar. The only thing I don't like about these is that they are not sealed. We'll see how they go...
How are these working out for you? Thanks for your help.
