HP LS3 question.
Old Mar 22, 2021 | 09:34 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Default HP LS3 question.
2008 LS3 Z51 automatic, I have a BTR Stage 1 cam kit, springs, locks all that stuff. 2009 ZR1 full 3" dual mode exhaust, real CAI. I'm getting 423 to the wheels with a tune. Will replacing the TB give me some more HP and then will I have to pay for another Dyno tune? Are there any other things to do (cheaply) that I can do for more power? Not interested Interested in long tube headers.
Old Mar 22, 2021 | 09:49 PM
old motorhead's Avatar
old motorhead
A bigger throttle body will only make your bank account smaller. Not much else to do (cheaply).
Old Mar 22, 2021 | 09:57 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Hp
LT’s will get you another 35 to 40. As far as another tune depends if your original tuner tuned out the rear O2 sensors.
Old Mar 22, 2021 | 10:10 PM
ls1121's Avatar
ls1121
so to port and polish my existing TB is a fruitless endeavor?
Old Mar 22, 2021 | 11:40 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
What DYNO was your Vette tuned on? remember it's not really about numbers - it's about peak performance
You could also do a Rod Mod and ported LS3 manifold and a Meziere EWP and a Under Drive Pulley set (10% or 25% UD) - some examples below
https://gwatneyperformance.com/produ...-manifold-mod/
https://www.c6performance.net/catalo...-p-497956.html
https://www.c6performance.net/catalo...-p-503187.html
https://rpmspeed.com/pulleys-balance...98vkr6qfb8rjq4
https://www.texas-speed.com/c-3357-p...ette-2008.aspx
My 2009 A6 Dyno'd at 452 RWHP and 422 RWTQ with the following mods:
VARARAM
VMAX Ported TB
Rod Mod and Ported LS3 Manifold
Meziere EWP
PatG Cam .600" 222/230 116LSA (Stock LS3 Heads with Dual Springs)
NGK TR5IX Plugs
Taylor 8.5mm wires (Blue)
2012/2013 - ZR1/Z06 exhaust manifolds, 2012/2013 - ZR1/Z06 3" Downpipe Cats, and 2012/2013 3" ZR1/Z06 Catted X-Pipe (4 Cats total)
Factory NPP exhaust (2.5")
3.42 Z06 Rear
YANK SS3200 Stall
Dyno Tuned - results listed above
Thanks,Matt
Old Mar 23, 2021 | 10:07 AM
ls1121's Avatar
ls1121
OK I'll start looking into a throttle body. Thank you all for your input.
Old Mar 23, 2021 | 09:05 PM
ls1121's Avatar
ls1121
My car is an 08 so I will need to see if the blade is gold or silver, early or late model 2008, correct? I just want to port and polish I understand that there is no HP gain from this just throttle response will improve.
Old Mar 23, 2021 | 09:37 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
If you don't increase the size of the actual throttle plate in a throttle body, I can't see how you are going to get any increase in HP or torque on a non-boosted engine.
You can port, shine and polish all you want, but you are still going to pull air through the same size orifice (throttle plate) ... you can only pull so much air through a certain size hole.
Wanna get more airflow through the throttle body? .. simple; . get a throttle body with a larger diameter throttle plate.
____________________________
Any particular throttle body will only flow as much air as the narrowest section of the throttle body ... and the narrowest area is where the throttle plate is located.
Old Mar 23, 2021 | 10:08 PM
GS_DAN's Avatar
GS_DAN
Look up LS3 intake manifold "Rod Mod". If you are doing the TB, you might as well get the intake ported and the rod-mod performed. You would definitely feel the HP gains over just a TB
With the BTR stage 3 cam, ported heads, and intake/tb mods, i put dow 512rwhp on a mustang dyno. M6 LS3
Old Mar 24, 2021 | 10:57 AM
ls1121's Avatar
ls1121
It has always been my understanding that you port (remove obstacles) and polish (smooth out) the inside of a throttle body to have a smoother less turbulent air flow. This having the effect of a better acceleration, not necessarily more horsepower.
Old Mar 24, 2021 | 11:12 AM
ls1121's Avatar
ls1121
The Internal Combustion Engine can be looked at as a large (6.2 liter) air pump. The ideal situation is that you have the hole where the air is being sucked in be equal to the hole where the air is being pushed out. This is the simplest way I can come up with to describe it. Though it is much more complicated than my description. My porting and polishing idea is just to smooth out that air flow, making it less restrictive. The ZR1 exhaust system I have installed on my car is big enough to handle almost anything I can put on the "air in" side of the engine. Making the hole bigger on the air in side would probably just increase my fuel costs and not do much for my power gains. Unless I installed a devise that would Force the air into the motor.
Old Mar 24, 2021 | 03:33 PM
madmatt9471
You can either send yours or buy new (see drop down box) works great with the Rod Mod Ported LS3 manifold too, like I mentioned in my earlier post above
https://gwatneyperformance.com/produ...-body-porting/
Thanks,Matt
Old Mar 26, 2021 | 01:22 AM
HOXXOH's Avatar
HOXXOH
Ported TB made 0 difference on my '08 A6. Back to back 1/4 mi passes. Two with stock TB, swapped to the ported TB and made two more passes. Lotsa luck expecting more power or quicker response.
Old Mar 26, 2021 | 06:40 AM
Turbo6TA's Avatar
Turbo6TA
Exactly what I was attempting to say in my post above, except everyone else seems to have a different idea ... oh well
To HP LS3 question.
